3 members (Graham, G4FUJ, RedThree, +8Rich), 229 guests, and 41 robots.
+8Rich 63
Adam12 62
John V6 55
9,215 Registered Users
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Tom Lehrer RIP
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,362
Posts813,301
Members9,215
Page 2 of 4 1 2 3 4
What are you using to get the depth with the cutter?
Hole saws are a relatively easy item to get hold of.
What are you using as an extension?
I have not done the baffle-ectomy but I was an electrician for many years and used drill motors with very long extension, sometimes two at a time made by Milwaukee for the large boring bits (2-3-4"dia bits) I suspect these or something like them would work with a carbide hole saw.
Check with an electrical construction supply.
1. Cordless drill
2. 18" long 3/8" drive extension with a socket on the end to drive the hole cutter
3. 38mm hole cutter.
O
O
During
After
I'm running S&S 'Stealth" Muscle open filter. I fitted a rain sock but to be honest I don't think it needs it! Runs perfectly in the wet.
2017 MTW Graphite Blue
Thanks Obie, really useful info and pics.
O
O
No problem.
I put pvc tape around the extension and socket to stop it coming apart.
One hole saw did both sides but use slow speed on the drill and oil as heat will quickly blunt it.
Nice
Good job Obie. That view from inside the pipe, is that from the front of the pipe near the cat?
And I too have the Muscle Cover wide open with no shield.
O
O
Yes, baffle number one looking from cat end.
Page 2 of 4 1 2 3 4
