1 members (JoeSpeetjens), 176 guests, and 30 robots.
+8Rich 94
Posts837,276
Page 1 of 4 1 2 3 4
#599758 17/10/19 03:40 PM
NeilL Offline OP
Hi everybody
Well long time since I posted on TM. But here I am.
Since you last heard from me life has been interesting to say the very least.
Of all the issues I have faced the biggest has been Prostate Cancer. I was formally diagnosed in Feb/ March as having aggressive tumours in my Prostate.
The blighter was removed ( involving a Robot!) on June 11th.
Since then it’s been a successful road into remission. I feel v lucky that the Cancer was removed before it had spread.
Yes I have ongoing issues but for now ...no cancer...phew!
Anyway enough about my nether regions.
I am hoping to buy a Morgan. Yehhhhh!
My problem is that I do not think I can afford a 1997 or later car.
So am faced with the choice of a Steel Bulkhead car. This is making me nervous!
I want to avoid buying a car only to find the Bulkhead is rusting and the potential costs of restoration.
Sooo.....your best advice would be most welcome.
It feels good to have posted this -and a big HI to all my MOG pals.
Cheers
Neil happy3
NeilL #599761 17/10/19 03:51 PM
Welcome back Neil! thumbs
Glad to hear things are working out.
Condition of bulkhead really depends on how a car has been looked after, obviously. There will be a good number out there with perfectly acceptable steel bulkheads.
Good luck with your search.
NeilL #599762 17/10/19 03:58 PM
Cant give any advice on the MOG but big fist bump for ridding yourself of the big C
Looking forward to seeing whatever you end up buying
Good luck Neil cheers
Bonesie
NeilL #599763 17/10/19 04:02 PM
Good to see you back Neil cheers
NeilL #599766 17/10/19 04:15 PM
Glad you are back Neil, I did wonder if you were all OK
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
NeilL #599772 17/10/19 04:35 PM
Congrats on your recovery process NeilL, as an owner of an 86+8 all be it restored circa Y2K, I can confirm that Graham is correct that there are bound to be Morgans out there like mine with no corrosion on the bulkhead, there are bound to be many more out there similar.
Good luck in your search.. thumbs
NeilL #599777 17/10/19 04:51 PM
Great to see you back, Neil! I posted on your other thread about CVH engines. Personally I wouldn't worry about a rusty bulkhead, most Mogs are pretty pampered. Easiest way to check is the most vulnerable area, which is at the side of the bulkhead under the rear of the wing.
NeilL #599778 17/10/19 04:53 PM
Formerly known as Aldermog
Neil,
good to hear from you.
Even better to hear that the Robot worked and you have been neatly separated from the tumour.
As to a Plus 8, I think that the ideal choice is possibly a car that has already had the steel bulkhead replaced with a stainless one.
All the best...
NeilL #599782 17/10/19 05:05 PM
Good to see you back Neil and great news that they have sorted out your nether regions and all is clear.
There are several cars around at the moment that fit the bill but as you know they are all subject to close inspection and a good test drive.
I have just spotted this one on Devon which might be a possible for you 1980 4/4 4 seater
NeilL #599785 17/10/19 05:12 PM
Ray Offline
Great to hear your on the mend. As to the bulkhead, hopefully you can find a genuine seller who won't mind if you look behind the carpet or trim in the foot well and door posts. Look there and it should be obvious if there is any corrosion present in the bottom bulkhead.PS where it bolts to the chassis.
Page 1 of 4 1 2 3 4
