5 members (Bunny, Bitsobrits, MJF, jbk, Soleng), 310 guests, and 48 robots.
+8Rich 89
by stumog - 26/08/26 10:24 AM
Topics49,843
Posts837,341
Christoph
#601151 26/10/19 03:44 PM
Scott69 Offline OP
Can I fit caparo self ajusting rear brakes, this includes back plate, drums,shoes, from a plus 4 to my 1986 4/4 Thanks
Scott69 #601153 26/10/19 03:54 PM
It may not be as easy as you think, I suspect your 86 has a Salisbury axle. Later cars have a BTR, so there will be differences in the backplates. You'll only really find out if you try.
Scott69 #601182 26/10/19 06:20 PM
Also the hand brake actuation is completely different, so you would have to change the linkage as well.
Fjemog
1993 Plus 8
Scott69 #601232 27/10/19 11:18 AM
Additionally the self adjusting system does not actually work optimally.
I have got much better results from the manual adjustment than I could ever achieve with the later system. As an added bonus the former is simpler to dismantle.
Perhaps the only plus point is that the handbrake actuation does away with the "spear" mounting that can puncture the fuel tank under extreme deformation.
Andy G
1999 +8 , Indigo Blue.
Scott69 #601250 27/10/19 03:20 PM
Scott69 Offline OP
Thank You for your comments, I think I will stick with my existing rear brakes for now, maybe it was me being lazy, the original brakes doesn't take long to adjust
MOG 615 #601253 27/10/19 03:51 PM
And that issue is easily solved by sticking a protective plate to the fuel tank that will protect against penetration. I used a 10mm aluminium plate.
Hamwich #601255 27/10/19 04:18 PM
I cut the spear off and used a MGB brake setup.
Button
