Topics49,842
Posts837,332
Posts: 12 |
Can I fit caparo self ajusting rear brakes, this includes back plate, drums,shoes, from a plus 4 to my 1986 4/4 Thanks
Posts: 22,356 Likes: 353
Posts: 22,356 Likes: 353 |
It may not be as easy as you think, I suspect your 86 has a Salisbury axle. Later cars have a BTR, so there will be differences in the backplates. You'll only really find out if you try.
Posts: 168 |
Also the hand brake actuation is completely different, so you would have to change the linkage as well.
Fjemog
1993 Plus 8
Posts: 2,272 Likes: 7
Posts: 2,272 Likes: 7 |
Additionally the self adjusting system does not actually work optimally.
I have got much better results from the manual adjustment than I could ever achieve with the later system. As an added bonus the former is simpler to dismantle.
Perhaps the only plus point is that the handbrake actuation does away with the "spear" mounting that can puncture the fuel tank under extreme deformation.
Posts: 12 |
Thank You for your comments, I think I will stick with my existing rear brakes for now, maybe it was me being lazy, the original brakes doesn't take long to adjust
Posts: 12,256 Likes: 317
Posts: 12,256 Likes: 317 |
And that issue is easily solved by sticking a protective plate to the fuel tank that will protect against penetration. I used a 10mm aluminium plate.
Posts: 1,943 |
And that issue is easily solved by sticking a protective plate to the fuel tank that will protect against penetration. I used a 10mm aluminium plate. I cut the spear off and used a MGB brake setup.
Button
