Topics48,346
Posts813,049
Posts: 945 Likes: 16
Posts: 945 Likes: 16 |
Tanks full or not, the fact that the front of the car weights much more so it "dives" even with someone driving it and fuel in the tanks (so pushing the balance point to the rear) really shows how close to the front the balance point is...
According to the Experience of a couple of colleagues here, the weight is 2/3 to the Front 1/3 to the rear, so the balance point is more or less 1/3 close to the Front wheels and 2/3 away from the rear one.
This said, you better never tow your M3W on a trailer with the M3W looking backwards! Or as the video shows.... you can be really scared!
Posts: 759 Likes: 23
Posts: 759 Likes: 23 |
Diving under braking is also a function of suspension geometry, not just weight transfer. Most road vehicles have some amount of anti dive designed in, but no idea how much they may have intended with the M3W.
Steve Late 2012 M3W
Diving under braking is also a function of suspension geometry, not just weight transfer. Most road vehicles have some amount of anti dive designed in, but no idea how much they may have intended with the M3W. Of course!  And I guess the M3W has no specific design to avoid this phenomenon… My comment was a reply of Skullmog's one saying he dived after a hump, not just braking. I should have quoted him (I understood he really flied!)
Posts: 1,789 Likes: 3
Posts: 1,789 Likes: 3 |
When I used to run a MK1 Elise to stop it falling off the 2 post lift a bag of sand had to be hung off the front towing eye to act as a counter balance.
Posts: 104 |
For the purpose of completeness our car: FL : 173.5kg FR : 177.5kg Rear : 226.5kg Total : 577.5kg
Indicated 71% fuel No driver or ballast Lightweight mudguards fitted, but slightly larger battery than original.
2012 G56 Stage 2 M3W 2007 Fiat Panda 100HP 1998 Lotus Elise (Cosworth Duratec) 1988 RF88 Van Diemen
G-R-E-A-T !!!!
Thanks a lot! Useful information.
Posts: 3,854 Likes: 2
Posts: 3,854 Likes: 2 |
FlatCapRacing, you must have G56 carbon fiber mudguards?
Thanks for the weights.
Posts: 712 Likes: 8
Posts: 712 Likes: 8 |
Does the carbon mudguards makes any difference in handling or comfort ?
Posts: 2,356 Likes: 2
Posts: 2,356 Likes: 2 |
10 kg less with light mudguards
Posts: 3,660 Likes: 48
Posts: 3,660 Likes: 48 |
Does the carbon mudguards makes any difference in handling or comfort ? A double benefit - they lighten your car and wallet at the same time
Red Leader
