3 members (BLUE+4, Joske Vermeule, xc68anc), 356 guests, and 54 robots.
+8Rich 82
Topics49,859
Posts837,498
Jonny72
#609359 22/12/19 01:22 PM
dmh Offline OP
The rubber seal on the rear edge of our Roadster hood has separated from the canvas hood.
Is there a particular glue I should use to re-seal please?
Thanks
David H
dmh #609365 22/12/19 01:42 PM
Any neoprene based glue like Bostik will work.
dmh Offline OP
Thank you John.
What should I use to clean the old grotty glue off thr rubber seal I wonder?
Thanks
David H
dmh #609394 22/12/19 04:27 PM
Toluene
Bonesie
dmh #609396 22/12/19 04:30 PM
The trick with gluing is very thin coats, leaving each to become very tacky before applying the next. Three coats on each surface minimum
Bonesie
dmh #609461 23/12/19 08:42 AM
Correct toluene, but ensure good ventilation. Toluene is heavier than air and sinks to the ground it then creeps away in a thin sheet. The flash point is I think 5c so avoid open flames sparks etc.
