10 members (Graham, G4FUJ, cerealsurfer, DCH, High Hamster, Montegue, JamesS, MartO, Joske Vermeule, TeddyAds, sewin),
303
64
Topics49,860
Posts837,522
Posts: 638 |
The rubber seal on the rear edge of our Roadster hood has separated from the canvas hood.
Is there a particular glue I should use to re-seal please?
Thanks
David H
Posts: 27,812 Likes: 749
Posts: 27,812 Likes: 749 |
Any neoprene based glue like Bostik will work.
Posts: 638 |
Thank you John.
What should I use to clean the old grotty glue off thr rubber seal I wonder?
Thanks
David H
Posts: 1,309 Likes: 5
Posts: 1,309 Likes: 5 |
Bonesie Current stead -'The Captain' Black +4 'Life is like a garden, dig it' *Joe Dirt
The trick with gluing is very thin coats, leaving each to become very tacky before applying the next. Three coats on each surface minimum
Correct toluene, but ensure good ventilation. Toluene is heavier than air and sinks to the ground it then creeps away in a thin sheet. The flash point is I think 5c so avoid open flames sparks etc.
