0 members (),
344
78
Topics49,861
Posts837,540
Posts: 6,669 Likes: 434
Posts: 6,669 Likes: 434 |
My 4/4 has been outside for 14months now, with just a morganhoods cover (more to keep it away from prying eyes). Four bikes down the side of the house, no covers. (and have been for 25+ years) I have no garage  As mentioned, regular use and good servicing is the key.
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
Your nearest approved dealer is probably now Bell & Covill who, in my experience, are excellent.
Give Richard Wright a call and I'm sure he'll sort out a test drive.
Red Leader
Posts: 9 |
Thanks for the advice all, it is much appreciated. Good to know 2014 is they key year for when the factory sorted some of the big issues, but that a well sorted earlier car is viable. And you've confirmed my suspicions that a well used car might be a safer bet as any issues are more likely to have already surfaced. I will buy on condition and history rather than age or mileage.
Are there any particular options I should be looking for that make the car easier to live with?
Will heed the advice on keeping it outside. It sounds like it's possible but not the best idea. I think I'll investigate renting a garage nearby, but not sure I'll be able to get one I can easily walk to. I did consider a carcoon before but I thought they were held down under the car's wheels, so a 3 wheeler won't be compatible. Has anyone used a carcoon with an M3W? If it works that might be my best bet.
Posts: 1,625 Likes: 25
Posts: 1,625 Likes: 25 |
Has anyone used a carcoon with an M3W? If it works that might be my best bet. A sheet of plywood under the rear wheel the width of the Carcoon will solve any problems.
Posts: 9 |
Has anyone used a carcoon with an M3W? If it works that might be my best bet. A sheet of plywood under the rear wheel the width of the Carcoon will solve any problems. I'm an engineer and I didn't think of that! I shall hang my head in shame.
Posts: 365 |
If the option is a Morgan outside or no Morgan I would opt for the Morgan outside and accept that stuff may not stay as perfect as I would want it. I tell myself that regularly anyway as life happens. To me there is nothing more fun than driving the Morgan around and even though I am not normally one to draw attention to myself it is fun seeing the smiles on people’s faces and the reaction by kids though you have to be prepared that when you come to a stop or get gas high odds of getting a lot of redundant questions and comments.
Options stage 1 and 2 from the factory if feasible as the Morgan runs so much better. I would also select the full windscreen and heated seats. If outside I would revisit the chrome pack as I am not sure how well that would do vs the elements plus it is a very expensive option but that is just my opinion.
2017 M3W Sport Green
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
2Sharp, +1 to your sentiments.
Not sure about the bright pack but it is indeed more expensive for sure. Mine came with the headlamps and the roll hoops in bright but I did not order it extra and they are holding up fine although it is pampered in an insulated heated garage.
Posts: 2,431 Likes: 17
Posts: 2,431 Likes: 17 |
Murphaj, further to my previous post the Machine Mart motorcycle garage would suit I think, 12 ft long and 6 ft wide, currently on SALE too! You’d have to be careful when garaging tho cos that engine and exhausts get very very hot!
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Good luck on driving through a 6’ wide opening.
Posts: 12,257 Likes: 317
Posts: 12,257 Likes: 317 |
I think I'll investigate renting a garage nearby, but not sure I'll be able to get one I can easily walk to. Given that an M3W is unlikely to be driven in inclement weather, then why not get a Pedelec to ride to the garage? You can leave it in the garage whilst out in the car. You can easily average 12mph, so a 10 minute ride extends your radius to 2 miles. Some of my neighbours have clubbed together and rented an industrial workshop/storage unit a couple of miles from their houses, they keep at least 6 cars and RVs there, plus assorted motorcyles and other kit. They pay £100/month each for it.
