6 members (Alistair, jbk, RichardV6, Gordon D, bmgermany, MartinB60), 159 guests, and 49 robots.
+8Rich 87
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,354
Christoph
Page 7 of 8 1 2 3 4 5 6 7 8
I'll say it again Roger, Fantastic work. Well done.
Online Sick
Hi to all!
Thank you for your nice comments, tipps, informations and thougths! cheers
It will take some time to install Rogers bump stops and do some test drives (with my wife). So better weather would be nice winky
After every testdrive the tooltray has to be taken out of the car.
I don't want to appear skeptical, I just want to prepare the conversion! I am very optimistic about the result after installation!
I will inform you like the others here!
Again: Thank you!
bmgermany. When I fitted Rogers bump stops. I drove the car without the tool tray or carpet or shelf. Allowed me to stop adjust stop adjust etc. I then drove around with just the shelf fitted until i was happy with the adjustment. Then cut a small block of wood to size so in the future could quickly put the stops in without the hassle.
If you do drive the car with the tool tray & shelf out, be prepared for a fair amount of noise and some sounds you will have never heard before.
Fitted a pair of Roger's Bump Stops today.
Although yet to road test, I have to say I am delighted with the quality of engineering that has been applied in the construction of these items.
Instead of a cheap and cheerful fillet weld, the stiffener plates transmit the vertical and lateral shear loads through a mortice and tenon type joint between the anchor plate and the bump stop mounting plate. This is then fixed with light weld on both sides for security. Altogether well thought through, with ample slots for alignment of both the bracket itself and the bump rubber.
I assembled layers of timber to a thickness of 32mm and placed this on the leaf springs for initial height setting of the bump rubber.
It was necessary to unbolt the handbrake cable fixing block to gain access. Fitted Nyloc M8 nuts to the U-bolts and Nyloc M12 nuts at the top of the bump stop hangers.
Thanks Roger - an absolutely marvellous device!
Chris
2015 Plus 4 Silverlake Blue
(2012 4/4 Sport Black)
Online Sick
Fitted Rogers bump stops some weeks ago.
First test drive with my wife today.
No Problems, no bumping.
Fantastic work Roger!
Fitted Rogers bump stops yesterday . They are really well made and easy to fit .
Well done Rodger.
Jimmy
2015 4/4 Sport Green
2018 VW Tiguan
1969 Morris Minor Traveller
1960 Morris Minor Saloon
Rog,
First drive out today with the bump stops fitted.
Drove over the huge tank traps in Sonning-on-Thames and then what passes nowadays for roads in South Oxfordshire.
Wow, what a difference! Unbelievable improvement to the ride. No banging or bottoming out.
A brilliant piece of engineering.
Well done Sir!
Rog Offline
Fantastic! Thanks Niall thumbs
Roger
Hi Rog, will the bump stops work on a 1993 Plus 8?
If so, can you ship to the US?
Thanks,
Ian
1993 Plus 8 Connaught Green
Various older cars and motorcycles
Big American Bulldog
1994 +8, BMW Calypso Red.
How do you open the boot?
