3 members (cerealsurfer, RedThree, Zach), 377 guests, and 37 robots.
+8Rich 91
Topics49,841
Posts837,316
Page 2 of 15 1 2 3 4 14 15
Rob82 #604205 19/11/19 08:28 PM
I'd suggest looking at some of the other 3 wheeler kits. I quite like the Pembleton for example! But otherwise good luck!
Rob82 Offline OP
Originally Posted by Jays ex Nero
You plan to use the shaft drive (Paralever) from the donor BMW. Any reason why you are not using the BMW bevel box rather than constructing a transfer box?
Intriguing project...I’m really looking forward to seeing some progress photos in time!
This is the correct answer;
John. If he is using the MX5 gearbox he needs to shift the output to one side to line up with the rear bevel drive. An easier option may be to use the BMW box but then you don't have a reverse gear. Some of the trike people use an electric motor for reverse and there is also a little reverse drive box available.
John, Thanks for posting the pics!
Rob82 #604286 20/11/19 01:46 PM
Rob82 Offline OP
Here are some pics of the parts acquired so far. The bearings for the intermediate housing and transfer case are ordered already as well.
PS, thats not me in the last picture, thats the guy I got the bike from lol.
PaulV #604288 20/11/19 01:58 PM
Rob82 Offline OP
I have looked at the Pembleton as well as many others. I can't stand the ones that someone just hacked the front off a bike and put a pair of wheels and seat on it. I love the look of the Pembleton but it uses FWD and a VW transaxle and just about all the other ones I have seen (that utilize a Motorcycle engine) are using the bikes transmission and either no reverse or some add on system. I wanted a true 5 speed and a robust drive line. It will take more effort initially but I feel it will be worth it in the end.
Rob82 #604305 20/11/19 03:48 PM
That is quite a project . Good luck.
Rob82 #604491 21/11/19 06:13 PM
Rob82 Offline OP
Here is where I am at on basic vehicle dimensions and drive train layout.
Rob82 #604496 21/11/19 06:19 PM
This is an amazing project which I shall follow with interest, best of luck with it.
Rob82 #604662 23/11/19 01:43 AM
Rob82 Offline OP
Got some driveline sketches done tonight.
Rob82 #604683 23/11/19 11:09 AM
Hi Rob.
Do you think the Paralever housing is strong enough for your project.In the sidecar world not everybody is convinced.On my BMW K1100 RS with EML Speed 2000 sidecar the Paralever is replaced by a steel substitude.
Rudolf
Morgan Aero8 S4 «Tango»
Fisker Ocean
Harley Davidson Livewire
BMW R100/7 , R100R
Moto Guzzi 254
Rudolf #604928 24/11/19 11:56 PM
Rob82 Offline OP
Originally Posted by Rudolf
Hi Rob.
Rudolf
No, I am not really concerned with the paralever housing, I have not heard of any failures of that system. where did you find an alternative? I assume the K series paralever is different from the R series.
