4 members (CooperMan, piquet, IcePack, mph), 283 guests, and 41 robots.
+8Rich 91
Topics49,841
Posts837,312
Page 7 of 15 1 2 5 6 7 8 9 14 15
Rob82 #610373 31/12/19 08:59 AM
Great work Rob and an unrelenting project.
Interested to know why you chose a chain rather than gears in the transfer intermediate.
Rob82 #610377 31/12/19 09:53 AM
+1 (not for the first time). Will you be fabricating a wooden tub and the bodywork yourself?
Mark H #610528 31/12/19 09:54 PM
Rob82 Offline OP
I went with a chain (13,300 lbf yield rating) because to retain the same direction of rotation I would have required 3 gears,shafts,ect. The gear setup would be more complex than required and noisy as well. Most Vehicle transfer cases I am familiar with utilize a roller chain,with more strands though , to transfer power. The T-Case I designed also allows me to mimic the original offset in the BMW Donor transmission making the Paralever basically a bolt on solution. The fatigue life using the components chosen should yield me many many years of maintenance free operation as well.
M3W55 #610529 31/12/19 09:58 PM
Rob82 Offline OP
All the chassis and bodywork will be fabricated by myself. I am not going to use a wooden tub however, I will fabricate it from steel and aluminum. The bodywork will be aluminum and composite.
Rob82 #610531 31/12/19 10:05 PM
Rob82 Offline OP
I spent a few hours today on the lathes turning out the caps for the transfer case. I now have about 90% of the machining done on the transfer case and internals. Now for some welding and finish machining.
Rob82 #610591 01/01/20 01:07 PM
Rob,
Great display of design and metal working skills here!
I have been proven wrong in ignoring posts on 3 wheelers.
Good-luck in 2020 with your project!
Cheers,
Bert
2025 Plus Six - 1909
2009 Roadster
1983 4/4 4str
Rob82 #613492 22/01/20 02:26 AM
Rob82 Offline OP
Been a while since an update. I had a setback on the transfer case lid. The more I looked at it the more I was unhappy with the casting structure in the middle and once I discovered a crack in it that was enough for me to start over on it. Fast Forward and I have now re-cast the lid and done so in a manner that allowed me to mill all the caps into it. I am much happier with this version and will use it as a learning experience.
I also have the materials now to machine the Intermediate housing as well and they will be next after I complete the transfer case.
Rob82 #613597 22/01/20 06:00 PM
Thanks again for the update, this is an amazing project and many of us here are willing you on the journey.
Rob82 #613948 25/01/20 05:06 PM
Really interesting, thanks for posting and please keep them coming.
BR
Colin
BR Colin
Rob82 #613953 25/01/20 05:18 PM
Great project.... Keep the updates coming!
Is that a duplex chain or twin chains on parallel sprockets?..... If the later keep an eye on stretch.... Twin chains have been used on high power bike engined single seater hillclimb racers..... What can happen is one chain stretches a bit, which puts more of the strain on the shorter one, which stretches... Etc, etc, etc...... For high stress chain drive (200+bhp driving wide sticky slicks) most people nowadays use single EK DRZ2 drag chain... Massively heavy side plates so very stretch resistant.... Not an o-ring chain but that wouldn't be an issue fully enclosed like that.
Great work... Look forward to seeing your progress.
