7 members (DaveW, Moggo, Calypso Red, AndyGoff, sprinty, Image, BobtheTrain), 321 guests, and 90 robots.
Topics49,847
Posts837,389
Page 4 of 6 1 2 3 4 5 6
SALMO #614724 31/01/20 08:20 AM
Thanks Geoff. I will look into your suggestions although wanted the simplest solution, so maybe an extra fabricated bracket utilising existing catch mounts. Main issue is that whatever bonnet stay pivot point I use, it will necessarily be that much closer to inside edge of bonnet in closed position.
RobCol #614733 31/01/20 09:07 AM
Richard, I thought all the 3.7's were supplied with 'factory' stays ?
CooperMan #614736 31/01/20 09:20 AM
Yes they are, but untethered ones. Having witnessed a gust of wind lifting the bonnet off same on a new car, I decided I wanted secured fittings each end and this thread has got me investigating. Have already purchased 6mm stainless rod and matching fittings from bearing boys.
RichardV6 #614739 31/01/20 09:35 AM
Yes, I must admit they are a bit 'basic' & mine reside in the spares bin
RichardV6 #614767 31/01/20 11:57 AM
Hi Richard, I was thinking about that this morning and the possibility of dog legs in the stay.
Perhaps £3 spent on a length of 8mm Ali tube from Wickes to experiment with?
Anyway, best of luck and I love the morgan script on black engine thingy!
Regards
Geof
Regards
Geof
70th Anniversary 4/4 (Duratec 1.8), model 1995
RobCol #614773 31/01/20 12:59 PM
Thanks again Geof. A lot depends on access to the fixings of existing lower bonnet catch on inside of footwell. Will know more when I next visit my garage although concerned the nuts are hidden under glued down carpet!
Will then take the easiest adequate solution to minimise fabrication work.
RobCol #615154 03/02/20 10:18 AM
I went the same way as Chris but put the males on the bonnets as it seems more intuitive pulling the catch down to engage them rather than across.
1972 4/4 2 Seater
RobCol #615162 03/02/20 11:04 AM
Looks good👍
Chris
2015 Plus 4 Silverlake Blue
(2012 4/4 Sport Black)
RobCol #615175 03/02/20 01:29 PM
Hi Tmg513
Did you mount the angle bracket underneath the bonnet catch to prevent it twisting round in use?
Chris,
I note hex domes on your bonnet catch. What's on the exterior? Back to back fittings?
Just interested
Regards
Geof
Regards
Geof
SALMO #615186 03/02/20 02:58 PM
Originally Posted by SALMO
Hi Tmg513
There was a bit of that plus the bracket fouled the angle that runs most of the length of the catch putting in on top.
1972 4/4 2 Seater
