10 members (nick w, howard, RichardV6, Grumpy2, Jensen1960, Rex_tulips, Gerry Seale, IcePack, +8Rich, Mauli),
266
Topics48,362
Posts813,328
Members9,215
Posts: 1,639 Likes: 20
Posts: 1,639 Likes: 20 |
On my car you can tease the switch out and test the switch connections but not sure on your model. Unfortunately the switch will be soldered to the pcb. A desperate long shot…. Sometimes relays can become sticky or lazy through lack of use. Start the car and take the engine up to around 1500rpm to get a healthy voltage out of the alternator to give the relay the best chance of working. Switch on headlights and then rapidly press the fog lights many times. If it is a sticky latching relay it may just come back to life.
Roger 2011 Plus 4
Posts: 1,961 Likes: 43
Posts: 1,961 Likes: 43 |
Bad tidings? Possibly the pcb board is U/S, a well known fault. £500+ if you can get hold of one that is.
Posts: 28,428 Likes: 180
Posts: 28,428 Likes: 180 |
Did you test the fuse, electrically, or just look at it?
Sold L44FOR 4/4 Giallo Fly '09 Gen2 MINI Cooper ragtop '90 LR 90 SW
Posts: 5,013 Likes: 32
Posts: 5,013 Likes: 32 |
MOT due Monday and the fog light switch is illuminated but when depressed does not stay in and no rear fog light on . Is there easy fix for limited electrical knowledge! I have a blank switch next to it that stays in when depressed ..is this a simple swop over option or any other ideas—- the stress to solve by Monday Any help appreciated Mark My aircon switch stopped working - exactly the same problem... illuminated when pushed in but did not stay in. B&C fixed it by removing the switch and cleaning it. Works fine now.
+8 4.8
Posts: 28 |
Yes fuse checked with meter
Never seen in non green
Posts: 28 |
One other thought —- could l solve this issue differently by putting new wiring loom, switch ,fuse etc in that is independent of the fault wherever it is ie a dedicated one off switch and power from battery direct etc for the fog lamp. Surely that would be legal for the mot ?
yes, you could do this but switch needs to have a tell tale when in the “on” position i.e. the switch itself lights up or you have a separate dash indicator light that comes on with the switch.
Posts: 28 |
Great thanks now an option with £30 parts
Posts: 1,799 Likes: 3
Posts: 1,799 Likes: 3 |
I'm only guessing but doesn't it have to be linked to the headlights on modern cars so it only comes on with the headlights and goes out when the headlight is switched off.
Only a thought, others will confirm or refute.
Bob
