3 members (Massi_torino, MJF, Simon), 212 guests, and 103 robots.
+8Rich 74
DaveW 52
Topics49,867
Posts837,628
Moggo
#616574 10/02/20 09:29 PM
On my 2011 Plus 4 underneath the dash on the drivers side, there is a knurled knob and a small push switch? Almost like a re-set switch. Has anyone idea what they are for? Like I have found with other things I am unfamiliar with, in the Owners Manual there is no mention!!!
"Marty" the Mog
Don't know about the push switch, but is anything happening when you push it? As for the knurled knob, you are sure it is not the regulator for the dash light intensity?
Robbie the Norseman
2004 V6 Roadster
Sherwood green
miles of smiles
miles of smiles
I think the push button is the odometer reset, it’s either that or the self destruct, push it and see.
The push button will be the trip reset. The knurled knob will be the dash dimmer.
Thanks guys.
Ejector seat?
Rob
Beware...that push button, as well as resetting the trip odometer, is also used to calibrate the speedo. If you depress it and hold whilst turning the ignition key to start the engine, it will go into calibration mode. A number will appear in the odometer space which if changed, will alter the calibration of the speedo. People have been known to do it by accident and then get stuck to reverse the process without knowing the original code.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
alb Offline
On my 2011 Plus four the small chrome button moves the clock hands on.
Another possibility for the push button is clock calibration. If its a Smiths one with no other means of adjustment on the clock itself then maybe, like mine, push and holding button will motor hands around at ever incteasing speed until desired time is reached.
Have you got your clock working yet though John?
Deejay #616605 11/02/20 12:06 AM
Originally Posted by Deejay
.... People have been known to do it by accident.....
http://www.talkmorgan.com/ubbthreads.php/topics/603691/re-2011-plus-4-speedo-not-working
grin2
