3 members (TBM, ChrisConvertible, Ncik P), 325 guests, and 34 robots.
+8Rich 92
Topics49,839
Posts837,301
Page 11 of 15 1 2 9 10 11 12 13 14 15
CooperMan #618090 19/02/20 11:45 AM
Rob82 Offline OP
Originally Posted by Uther
So that’s how splines are cut, very cool. Wish I had a lathe......and knew how to work one πŸ˜„
Thanks for showing that. This whole process is riveting. There is an illustrated book in this whole project πŸ‘πŸ»
Brilliant Rob, how do you accurately turn the chuck for each spline 'cut' ?
The major O.D. is turned down in the lathe, then it's off to the mill. The mill has a rotary table with indexing plates that accurately divide 360 deg. into the number of required splines. (32 in this case so 11.25 deg/index) The fit is achieved using thread wire gauges and a lot of measuring.
Rob82 #618102 19/02/20 01:39 PM
Ray Offline
Yes, keep up the good work.
Rob82 #618434 21/02/20 08:36 PM
Rob82 Offline OP
Got to work today on the flanges for the intermediate driveshaft. I had just enough material to make both flanges on the lathe. Now I will make the program for the mill to drill the bolt circles and mill out the pocket for the bolt heads. The tap is on order and I should have it Monday so the goal is to finish them up by then. All that's left after that is to machine on the intermediate driveshaft is a spacer/washer to lock the one coupler in place. Then it's heat treat and final assembly.
The next major assembly to work on is the intermediate housing.
Rob82 #618436 21/02/20 08:53 PM
Rob82 #618438 21/02/20 09:02 PM
Thanks for another fascinating update thumbs
M3W55 #618456 22/02/20 02:10 AM
Rob82 Offline OP
Originally Posted by M3W55
LOL my printer is't nearly big enough. 3D printing (FDM in my case) has it's place though and there will be 3d printed parts on mine.
Rob82 #618731 23/02/20 11:02 PM
Rob82 Offline OP
I got the crankshaft adapters finished up except for tapping today. These are the last parts of the intermediate driveshaft to be fabricated.
Rob82 #618746 24/02/20 07:15 AM
This is outstanding. Conceiving such a project is admirable in itself, even more so having the courage to get on with it in real life. The speed of your work is also impressive, so many DIY projects tend to slow down or even halt after a while. Your skills as a designer and craftsman are the most impressive I have seen on this site. And I am extremely grateful for your generosity in photographing and describing your work as it progresses. Good luck with the continuation!
Robbie the Norseman
2004 V6 Roadster
Sherwood green
Rob82 Offline OP
Thanks for the kind words. I am sure the speed will slow down a bit once the drive line is complete as I will have to then fabricate a frame building table and start figuring out the framework. I have wanted a M3W for years and am determined to have a version of one. This project I figured would take between 2 to 2.5 years to complete, hopefully with a rolling chassis by this fall. The whole vehicle has to be built, then tore completely down for paint,powder coat,and to do some work to the engine and transmission. Then it will be re-assembled for the final time and put on the road.
Rob82 #622681 13/03/20 10:50 PM
Rob82 Offline OP
been a while since last post. I finally got around to milling out the adapter plates for the intermediate housing. I made a little boo boo on the BMW plate but it's cosmetic and I can fix it so no big deal. They fit well and the next step is to finalize the length of the hex tube and machine it.
