4 members (TeddyAds, Martin W, Pigiron, BLUE+4), 268 guests, and 36 robots.
+8Rich 92
Topics49,838
Posts837,296
#621515 08/03/20 03:17 PM
O
Obie Offline OP
O
May be of interest to owners of M3W with the loop in the rear brake line.
Noticed that mine was hitting the underside of the tray and must have been stressing the line.
Easily cured by cracking the pipe nut while holding the fitting on the wheel cylinder and rotating down a bit.
Obie #621517 08/03/20 03:33 PM
This brings up a question I have had since I saw that brake line for the first time.
Why is there a loop in it?
Obie #621519 08/03/20 03:42 PM
O
Obie Offline OP
O
It makes it possible to remove the rear wheel without disconnecting the brake line.
Obie #621522 08/03/20 03:57 PM
Thanks Obie, apparently MMC anticipates removing that wheel a lot.
The one time I changed the tire (at 1k miles) I put a Speed Bleeder on the slave cylinder making the bleed process a one person job. I don’t know if anyone makes a quick disconnect for a brake line that captures the fluid so the possibility of a mess being created is minimized.
High Lightspeed. Answer to your question is yes.
Air force hydraulic couplings are a two piece affair, male and female, self sealing both ends.
Thanks John, I believe I see my next mod😎👍
Obie #621574 08/03/20 07:36 PM
I repositioned my rear line to be tidy and straight, with the loop moved forward, behind the seat. Actually instead of a loop, it's now more of a large radius curve, and easily allows the wheel to slide back and off the swingarm. A zip tie ensures it remains clear of any pinch hazards.
Late 2012 M3W
Obie #621580 08/03/20 07:54 PM
Nicely done Steve!
Obie #621597 08/03/20 08:58 PM
O
Obie Offline OP
O
Good idea, I’ve got to remove the boot liner again now!
Obie #621619 09/03/20 12:09 AM
And enough around the bell housing to be able to pull that line all the way forward.
