0 members (), 323 guests, and 93 robots.
+8Rich 84
Topics49,860
Posts837,485
Jonny72
#623614 17/03/20 07:10 PM
Pmh44 Offline OP
I have a 1996 4/4 narrow body with some tatty 5.5 x 15 wire wheels. Does anyone know if you can replace them with 6 x 15's wires. cheers paul.
Pmh44 #623625 17/03/20 07:26 PM
It's worth measuring up to check, especially the clearance between kingpin and tyre, but if you stick with a similar tyre size you may be ok. IIRC the 5.5" rims are fitted with 185 section tyres as standard, which is also a good fit on a 6" rim. The other suitable size for 6" rims is a 195, ie only 5mm wider each side so you may get away with fitting those too. Personally I'd stick with the 185s, fitting overly wide tyres to a 4/4s means you lose a lot of agility.
Pmh44 #623670 17/03/20 09:35 PM
I fitted wider wheels and tyres to my 4/4
They rubbed badly on fully lock and the Morgan handled badly.
I am now back to the skinny wheel and tyre it handles so well.
I have 5 spare wheels and tyres in my garage!
Free to anyone
Pmh44 #623680 17/03/20 10:32 PM
What tyres are fitted on your wheels?
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
+1
5" rims and 165 tyres are perfect for 4/4s IMO.
Pmh44 #623698 18/03/20 07:02 AM
TBM Offline
I've gone for 5.5" rims, 205 back and 195 front.
I'll let you know how I get on (if I ever get my rear axle back together wink )
+1
I too will go back to narrow 165x80r15 this spring.
I had 185x70 for the last 5 years.
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
Pmh44 #623756 18/03/20 10:48 AM
Narrow tires reinforce the classic look of the Morgan 4/4. And with the 165 Vredesteins the car drives very well.
2003 Morgan 4/4 2-seater
Pmh44 #623787 18/03/20 01:25 PM
I was going to fit wider tyres on my 4/4 when I changed to the 2 litre engine with 160 bhp.
Listening to comments on here I decided to stay with the 165's and fitted Vredestein T-Trac2 which are perfectly adequate, handle very precisely and look great with the narrow body.
Bob
2009 Black Roadster
Pmh44 #623803 18/03/20 02:12 PM
I guess it’s down to why you want wider wheels and tyres....looks or handling. I fitted wider Avon’s on my 4/4 and it lost the agility in my view. Ok, it went round corners a bit more securely but you lost that lovely ability to lose the rear end intentionally and quite safely. That was one of the lovely things about the 4/4.
Jays. Ex Morgan owner. 1967 MGB Roadster.,
