6 members (paulmog, cerealsurfer, BLUE+4, Craig Jezz, linklaw, RedThree), 276 guests, and 38 robots.
+8Rich 91
by stumog - 26/08/26 10:24 AM
Topics49,843
Posts837,336
Christoph
SELF ISOLATE YOUR THREEWHEELER WITH PHIL
With the current restrictions due to covid19 I understand the reluctance of people to come and work beside me for their Centa cush drive and bevel box mounting upgrades. I am, for the duration of the restrictions, prepared to carry out the work for you - working alone, at no extra cost. The work will probably take a day or two longer but I will not charge for the extra hours. Prices on my website will be honoured.
If you can get your car to me or if you want me to collect ( maintaining a sensible and healthy distance from each other ) then I will carry out the work and provide you with some pictures as I go along - a sort of “virtual upgrade experience”
Stay safe and well.
Phil
Boy do I wish you lived in my area! I would be beating a path to the door of your shop:-)
3Gs Offline
Use of a 'social distance doughnut' is encouraged...
Ha!
Yesterday I removed my Centa cush drive rubber barrels, checked them and got them back in in under an hour, an easy DIY job.
I would rate the Bleazey cush drive modications as number 1 of all M3W mods including power upgrades, exhausts, shock absorbers etc.
A happy customer.
PaulR
Stay safe and well.
Phil
That's a fantastic service you're offering there Phil. Taking on the extra work at no extra charge is very generous of you. thumbs
Andy
Excellent modifications, totally recommended.
Any news of new stuff in the pipeline Phil?
A few people are asking about chain final drive and I have offered to do one or two but the big drawback is this. At the moment, I cut the teeth off the old final drive belt sprocket to make a chain sprocket carrier which means you can't convert back without buying a new belt sprocket and I guess the price would be prohibitive - if you can get one at all. I am hoping to get an old bevel box or sprocket to use for identification of the involute spline so that I can make carriers from scratch. Anybody got one they don't want?
There are significant advantages to chain drive :-
1/. The chain only costs about £100 and can be replaced without removal of the swinging arm and bevel box.
2/ The sprockets are cheap and easy to change which also means you can change the overall gear ratio.
3/ There is less conflict between chain alignment and vehicle centre line alignment - a chain will allow for small misalignment.
4/ The drive belt will track differently on over run braking and is difficult to keep quiet, especially if the sprockets are showing signs of wear. - use washing up liquid to quieten it if you want but it sounds wrong to me.
Watch this space - as they say.
