1 members (Saxonian), 266 guests, and 69 robots.
+8Rich 81
Topics49,849
Posts837,424
Page 3 of 26 1 2 3 4 5 25 26
SFG #625723 25/03/20 11:58 AM
SFG Offline OP
Heinz,
Pm sent
Stuart
SFG
2012 4/4 Sport
SFG #625848 25/03/20 08:45 PM
I don't have the problem but very interesting reading for future reference and a fantastic write up from Heinz especially in his second language. This is what forums are about to me.
Hope you get to the bottom of this soon Stuart.
Rob
SFG #626367 27/03/20 08:46 PM
SFG Offline OP
SFG
2012 4/4 Sport
SFG #626371 27/03/20 08:58 PM
Any updates Stu ?
Craig Jezz
SFG #626387 27/03/20 09:31 PM
SFG Offline OP
I’m obeying the health precautions of 10 Downing Street and not using the car. If they’re safe, then we all are!
SFG
2012 4/4 Sport
SFG #626930 30/03/20 01:31 PM
SFG Offline OP
I have found a broken terminal on the brake pedal switch.
1. There are two switches, is this a back-up feature?
2. Do they do different things?
3. Could this be causing some kind of voltage spike affecting the accelerator?
Luckily I’ve got 7 foot arms so I can undo the little guard that’s bolted through the floorboards
SFG
2012 4/4 Sport
SFG #626932 30/03/20 01:36 PM
SFG Offline OP
And do I have to adjust the switch when I replace it or is it just bolt in?
SFG
2012 4/4 Sport
SFG #627017 30/03/20 08:52 PM
Ive noticed there are two brake pedal switches on mine too but don't know why either. Can anyone else tell us?
Are the brake lights still working with only one switch working? Its unlikely but could one switch be for the high level brake light? Easy to check for both I suppose.
If you replace the faulty switch I would take a photo of its placement before removing. I assume that both are adjusted the same amount.
Finally I would have thought that the brake light switch is a separate problem than the loss of power unless someone can explain otherwise!
Rob
Rob, the second switch is the stop fueling signal to the ECU when you brake.
SFG #627023 30/03/20 09:06 PM
SFG Offline OP
Interesting- if the stop fuel switch to the ecu has a bad connection, what might be the result, I wonder?
SFG
2012 4/4 Sport
