8 members (Fuel.inj, Grumpy2, Hamwich, IcePack, SwissMogFan, Graham, G4FUJ, Simon, Julian BB),
307
35
Topics49,915
Posts838,218
Posts: 2,096 Likes: 75
Posts: 2,096 Likes: 75 |
Reading all these...Rock around the CLOCK, comes to mind!
Posts: 9,554 Likes: 134
Posts: 9,554 Likes: 134 |
2002 car with single Aston filler. Only had a blowback once, possibly because of pushing the nozzle in too tightly and blocking off venting.The pipe goes into the tank directly below the filler with a slight offset so no long pipe with bends. I tend to slowdown the flow towards the end if filling the tank full.
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
If you have one of those spring loaded metal flaps inside the neck, then the hinge position makes a difference. It rotates with finger pressure. I can't remember if I have the hinge at 12o'clock or 6o'clock, but one position works really well.
Posts: 52 |
As with Ken, I've never had any problem with my 2003 +8 Anniversary Model - except remembering which of the many keys fits..
35th Anniversary Plus 8
Posts: 2,121 Likes: 71
Posts: 2,121 Likes: 71 |
As with Ken, I've never had any problem with my 2003 +8 Anniversary Model - except remembering which of the many keys fits.. If this helps: Any key - from any morgan owner- fits..
Posts: 7,435 Likes: 122
Posts: 7,435 Likes: 122 |
When I picked up my first Morgan, I was always recommended to fill at 11 or 1 oclock It took me years until I realized by chance that I could also successfully refuel in the evening hours.
Posts: 28,914 Likes: 354
Posts: 28,914 Likes: 354 |
Posts: 14,750 Likes: 158
Posts: 14,750 Likes: 158 |
This is a topic that comes up fairly regularly. I seem to remember there was some discussion at one stage about an inner section that was free to rotate and was better positioned in a particular way.
For some reason I don't normally have any problem with mine.
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
Hi friends,
Little question... Is it just me, who is entirely incapable, or ist that a feature of the +8?
How long does it take you, to fill up your Morgan?
Sunny greetings, Ivo
Ivo, 2013 Plus 8... With the Monza style cap and the insert with a flap, and which is free to rotate. I've come to the conclusion that ease of filling depends on multiple factors. 1. The pump delivery speed: some pumps are det at a higher Liter/min rate than others. 2. The brand of petrol: some brands seem to foam more than others. 3. The position of the flap, the hinge point must be at the top. 4. The sensitivity of the trigger. At a petrol station that I used to use regularly they had new pumps and it went from an easy fill to almost impossible. And,,,.Possibly the phase of the moon? Sometimes I get to fill a tank with no false stops, other pumps cut out every few seconds unless I let the fuel trickle in at a slow rate. On one occasion I had a voice from the intercom ask me if there was a problem because it was taking so long. Peter
Posts: 2,433 Likes: 17
Posts: 2,433 Likes: 17 |
There is a fix for the 4.8 plus 8. Mine was virtually impossible to fill in less than around 10-15 minutes, now perfect. It was done FOC as it’s possibly a safety issue. Two hours work so not widely publicised .
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
