3 members (stefan s, Luddite, +8Rich), 258 guests, and 97 robots.
+8Rich 82
Topics49,849
Posts837,425
Page 4 of 26 1 2 3 4 5 6 25 26
SFG #627025 30/03/20 09:08 PM
It's just possible it's intermittent and giving you a very sudden drop in power. Certainly worth swapping the switches over and checking there is no power loss but of course the brake lighting would then be dodgy. A new switch on the fuel one would be best if possible the wiring diagram will tell you by colour which is which, sorry not sucking eggs here just trying to help.
SFG #627028 30/03/20 09:10 PM
SFG Offline OP
Bingo, thanks Rich
Heinz are you seeing this?
During servicing the day before, the technician noted that the brake lights weren’t working and found a fault on the switch. But that should have been the brake light switch. Interesting.
SFG
2012 4/4 Sport
SFG #627029 30/03/20 09:12 PM
Wouldn’t the OBD reader pick this up though Rich ?
Craig Jezz
I've never had the need of one Craig so I can't answer that one, logic tells me no though because it would have to know when you are braking wouldn't it grin2
And that would be a very clever machine to know that thumbs
SFG #627032 30/03/20 09:17 PM
SFG Offline OP
Craig, the switch is on/off I presume, so maybe the OBD would deem it legitimately off?
SFG
2012 4/4 Sport
SFG #627034 30/03/20 09:20 PM
Originally Posted by SFG
Bingo, thanks Rich
If the 2 switches are "ganged" could it be they are out of adjustment ? If so this would tie the two faults up.
My Plus 8 only has the hydraulic switch but my 4/4 Sport had the 2 and I had to change the brake light one before one MOT.
SFG #627036 30/03/20 09:31 PM
Craig, the switch is on/off I presume, so maybe the OBD would seem it legitimately off?
Sounds like you might have cracked it
cheers
Craig Jezz
SFG #627041 30/03/20 09:37 PM
SFG Offline OP
Rich, Here’s the two switches, wiring removed and you can see the broken terminal on the right of the RH one. That wire is green/purple.
It looks like there is no adjustment.
Waiting to hear if Uncle M has a switch in stock
SFG
2012 4/4 Sport
SFG #627043 30/03/20 09:45 PM
Good shot SFG and good find - the adjustment is carried out on the back nut which is a skeletal affair the other side of the mounting bracket from the alloy upstand the knurled locking ring being the other side of it nearest the black actuator. Is the green/purple the fuel one ?
SFG #627048 30/03/20 10:07 PM
SFG Offline OP
According to this Green /purple is the brake light switch. Still searching for the fuelling switch on here
Ok I see the back but, looks hard to get to
SFG
2012 4/4 Sport
