My 1994 plus 4 has the Perspex wind deflectors fitted onto the windscreen and I’m not sure they look right. I know they’ll come off easy enough but what size are the screws that will need replacing? Not of my metric screws will fit so I think they’re either UNF or BA. Anyone know the size and where I’d get replacements please?
I got mine from Ebay and you are right they aren’t metric
I’ll look back and see if I made a note of what they are
One way you can do it is to measure the precise diameter in mm’s using a gauge and then consult the UNF and BA charts to identify the correct size machine screw
Just remember 25.4mm to an inch when doing your calcs
