9 members (John Winn, BillHart, Rog G, mph, howard, Graham, G4FUJ, The Flitting, Lordofthewings, RJW),
292
38
Topics48,349
Posts813,101
Members9,212
Posts: 103 |
My 1994 plus 4 has the Perspex wind deflectors fitted onto the windscreen and I’m not sure they look right. I know they’ll come off easy enough but what size are the screws that will need replacing? Not of my metric screws will fit so I think they’re either UNF or BA. Anyone know the size and where I’d get replacements please?
Tony
1994 Connaught Green Plus 4
Posts: 11,610 Likes: 43
Posts: 11,610 Likes: 43 |
My 1994 plus 4 has the Perspex wind deflectors fitted onto the windscreen and I’m not sure they look right. I know they’ll come off easy enough but what size are the screws that will need replacing? Not of my metric screws will fit so I think they’re either UNF or BA. Anyone know the size and where I’d get replacements please? I got mine from Ebay and you are right they aren’t metric I’ll look back and see if I made a note of what they are One way you can do it is to measure the precise diameter in mm’s using a gauge and then consult the UNF and BA charts to identify the correct size machine screw Just remember 25.4mm to an inch when doing your calcs
Posts: 1,470 Likes: 7
Posts: 1,470 Likes: 7 |
Remember to watch the length ! Don’t crack the screen!
Posts: 310 |
The note I have made from another forum is that they are 10-32
However I did visit the company that makes the screens and they said the screws are 1/4 whitworth. I have a spare screen and will check
--------------------------- Mike Smith
2007 +4
Posts: 310 |
I have checked my spare screen (9 stud) and a 2 BA screw fits, and a 10-32 will also fit, the tpi is very close. I expect the original fit is 2BA and someone in the USA has found that a 10-32 does the job
2007 +4
Posts: 103 |
Thanks everyone. Found a place where they’re literally pennies each so ordered a set of BA and also the 10-32 just in case. Thanks again
Tony
Posts: 310 |
I checked a couple of windscreen frames I have stored away, which includes a factory 'easy up', and they have the same thread.
2007 +4
Posts: 103 |
Just to close this out, the correct size is 2BA. The 10-32 would fit (by forcing it) but I think it would ultimately knacker the thread. Or, at least this was the case on my plus 4
Tony
