0 members (), 128 guests, and 27 robots.
John V6 63
My Goodwood Revival 2026
Clutch for a 1982 4/4
DVLA frustration.
Old Book
by Pundit - 21/09/26 01:39 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,940
Posts838,603
Page 12 of 53 1 2 10 11 12 13 14 52 53
Originally Posted by John V6
Must have been a fun party.
A couple of Oktoberfests at home, plus focusing on asking beers while travelling. A lot of fun indeed cheers
www.speedymarmots.com
Originally Posted by Arwyn Williams
I got my Plus 4 started after a 27 year lay up!! First turn of key after spinning it over with plugs out and oil down bores to build up the oil pressure
Delighted!
Mind you, my neighbours weren't when a pall of blue smoke settled around the neighbourhood
Kind regards
Arwyn
Well done, 27 years is a long wait
I got my Plus 4 started after a 27 year lay up!! Delighted!
Kind regards
Arwyn
I rather doubt it was "bodged up" either!
Now you just need the opportunity to drive it smile
I took the lawnmower out yesterday for the first time, the handle to engage the blades was seized and while it was dismantled I took the opportunity to repair some corrosion.
Repaired with tin cut from the side of an old computer case, fixed with self tapping screws, cut the points off and covered with silicone to prevent from working loose.
Can't weld won't weld (don't own one) banghead
Gordon Duguid
John V6 Offline OP
Champion bodging. Well done.
Probably the best use for an old computer, too! laugh2
FINISHED! The new picture made of beer caps is hanging on the wall…
cheers
Nice, that's about a years worth of supping I guess?
Ah, cork stopper mounts, make that a year and a half laugh2
06 Saab 93
John V6 Offline OP
It looks great. All I have done is put in a small pond in the garden.
After our daughter dropped this in for a repair some weeks ago I finally decided to start
It's a dehumidifier BTW
Cleaned out all the resident spiders & a bit of simple 'is there power' testing, still no joy
So decided to move to a bit of brain surgery, it's ridiculously complex with magnetic trip switches, % humidity, fan speeds, bla bla
Anyway after wasting over an hour, the patient failed to recover & I gave in - defeated and an epic fail on my part, there's not much that I won't have a go at, but sadly beaten by this one
