8 members (AMorgan, Luddite, stumog, JohnHarris, JMcL, TBM, Jon G4LJW, Joske Vermeule),
285
103
Topics49,872
Posts837,686
Posts: 102 Likes: 1
Posts: 102 Likes: 1 |
So today's lock down task: I decided to remove the tool tray to inspect underneath. First thing I discovered was the the two screw at the front just went round and round, appears they have snapped off ![[Linked Image]](https://www.tm-img.com/images/2020/04/10/20200410_123550.md.jpg) So I will have to replace those. What I discovered was that the nearside handbrake cable went between the shock and the mounting pole, this means a tight turn off the back of the hub and then signs of chaffing on the extra rubber around the cable (car has done less then 10,000 miles) ![[Linked Image]](https://www.tm-img.com/images/2020/04/10/20200410_112157.md.jpg) So I decided to reroute the cable around the other side of the mounting pole, which to my inexpert eye looks much better. What next? I know clean up the battery terminals.
Tim Plus 4 2018
Posts: 27,817 Likes: 749
Posts: 27,817 Likes: 749 |
Tim & that is the routing as it should be.
Posts: 2,093 Likes: 74
Posts: 2,093 Likes: 74 |
When you next remove the off side rear wheel, have a close look at the handbrake cable as it curves down towards the brake drum. Splitting of the outer sheath at this point is a common issue and eventually results in rusted, seized or even broken inner cable. I wrapped mine in denso tape in this area.
Posts: 2,116 Likes: 68
Posts: 2,116 Likes: 68 |
About the screws: Same on my car! Two fake screws fixed in the air .... :doh
Posts: 8,684 Likes: 413
Posts: 8,684 Likes: 413 |
About the screws: Same on my car! Two fake screws fixed in the air .... :doh Probably caused by being screwed directly into the ash frame with a power screwdriver and no pilot hole. Screws made from cheese doesn't help either. Replace with stainless but you won't be able to use same hole location.
[/quote] Probably caused by being screwed directly into the ash frame with a power screwdriver and no pilot hole. Screws made from cheese doesn't help either. Replace with stainless but you won't be able to use same hole location. [/quote] That would be fine but at my car this 2 screws have been cut and there was no ash frame at this place just "air". I didn't find a hole in this area of the In the ash frame either So I think someone at MMC made some screwdummies!
Posts: 6,672 Likes: 438
Posts: 6,672 Likes: 438 |
About the screws: Same on my car! Two fake screws fixed in the air .... :doh Probably caused by being screwed directly into the ash frame with a power screwdriver and no pilot hole. Screws made from cheese doesn't help either. Replace with stainless but you won't be able to use same hole location. I carry a box of cooking matches in my car (safety ones of course). If I ever get a loose wood screw while out and about, a couple of neatly trimmed matches poked in the whole make a suitable fix and give the screw plenty to bite on. If I'm at home, I use a touch of woodglue to help.
About the screws: Same on my car! Two fake screws fixed in the air .... :doh Probably caused by being screwed directly into the ash frame with a power screwdriver and no pilot hole. Screws made from cheese doesn't help either. Replace with stainless but you won't be able to use same hole location. I carry a box of cooking matches in my car (safety ones of course). If I ever get a loose wood screw while out and about, a couple of neatly trimmed matches poked in the whole make a suitable fix and give the screw plenty to bite on. If I'm at home, I use a touch of woodglue to help. I used to use matches too. But since I own the MORGAN and because I am sometimes a perfectionist, I have bought various round rods made of beech wood that I use as wooden dowels.
That is up market. I follow the trick taught me by my Grandfather of using a match(es) & if available wood glue.
Posts: 22,366 Likes: 354
Posts: 22,366 Likes: 354 |
Broken off screws can be extracted using a hand pin chuck, but it's time consuming. Make a hole then tap a modellers three faced file into the end and draw out by unscrewing with pliers...…………...
Where possible I try to fill holes with a sawdust/wood glue mix, which can then be re-drilled……..
I also use matches...and ash always needs a pilot hole...…….try drilling it and it's exceptionally hard.
