2 members (Hamwich, RedThree),
175
44
Old Book
Topics49,940
Posts838,604
Posts: 961 Likes: 21
Posts: 961 Likes: 21 |
Must have been a fun party. A couple of Oktoberfests at home, plus focusing on asking beers while travelling. A lot of fun indeed
Posts: 8,728 Likes: 514
Posts: 8,728 Likes: 514 |
I got my Plus 4 started after a 27 year lay up!! First turn of key after spinning it over with plugs out and oil down bores to build up the oil pressure
Delighted!
Mind you, my neighbours weren't when a pall of blue smoke settled around the neighbourhood
Kind regards
Arwyn Well done, 27 years is a long wait
Posts: 28,918 Likes: 354
Posts: 28,918 Likes: 354 |
I got my Plus 4 started after a 27 year lay up!! Delighted!
Kind regards Arwyn I rather doubt it was "bodged up" either! Now you just need the opportunity to drive it
Posts: 1,236 Likes: 40
Posts: 1,236 Likes: 40 |
![[Linked Image]](https://www.tm-img.com/images/2020/04/10/IMG_20200410_092427148.jpg) ![[Linked Image]](https://www.tm-img.com/images/2020/04/10/IMG_20200410_102036570.jpg) ![[Linked Image]](https://www.tm-img.com/images/2020/04/10/IMG_20200410_102023407.jpg) I took the lawnmower out yesterday for the first time, the handle to engage the blades was seized and while it was dismantled I took the opportunity to repair some corrosion. Repaired with tin cut from the side of an old computer case, fixed with self tapping screws, cut the points off and covered with silicone to prevent from working loose. Can't weld won't weld (don't own one)
Gordon Duguid 2014 Duratec engine plus 4, Montreal blue.
Posts: 27,864 Likes: 775
Posts: 27,864 Likes: 775 |
Champion bodging. Well done.
Probably the best use for an old computer, too!
Posts: 586 Likes: 21
Posts: 586 Likes: 21 |
Nice, that's about a years worth of supping I guess? Ah, cork stopper mounts, make that a year and a half
"DOT" 35th Anniversary Edition Plus 8- family owned from new. Rolls Royce Pewter. 06 Saab 93
It looks great. All I have done is put in a small pond in the garden.
After our daughter dropped this in for a repair some weeks ago I finally decided to start It's a dehumidifier BTW Cleaned out all the resident spiders & a bit of simple 'is there power' testing, still no joy ![[Linked Image]](https://www.tm-img.com/images/2020/04/08/Dehumidifier-2.jpg) So decided to move to a bit of brain surgery, it's ridiculously complex with magnetic trip switches, % humidity, fan speeds, bla bla ![[Linked Image]](https://www.tm-img.com/images/2020/04/08/Dehumidifier-1.jpg) Anyway after wasting over an hour, the patient failed to recover & I gave in - defeated and an epic fail on my part, there's not much that I won't have a go at, but sadly beaten by this one
