3 members (MartO, MartinB60, Graham, G4FUJ), 285 guests, and 77 robots.
Topics49,848
Posts837,408
DazMog, The Impaler, tlchzj79
#631004 17/04/20 07:23 PM
TalbotR Offline OP
Have been looking for next car for some time, what one would you have ? 2018 3.7 roadster nice spec about 50k or 2019 plus 4 @ circa 40k not top spec,
Can you test both on the road or are they perhaps sold before driving is allowed again? I would like to experience both during a drive.
Given a choice of such diverse cars, in your shoes I would not make a decision without driving them both.
Costock, UK
Disco 5
Having owned both it’s the Plus 4 every time for me.
Chris
2015 Plus 4 Silverlake Blue
(2012 4/4 Sport Black)
Roadster for me, but you’ve got to drive both. The right car will find you.
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
Every Morgan is different to drive , I found out this early on in my learning curve ....well worth driving quite a few , its a very interesting experience ! sherlock
A tipping point may be whether or not the 2018 Roadster has a 5 link rear (coilspring dampers). It came in around April 2018.
Drive both.
I have a 3l Roadster & prefer it to the 3.7l because :-
1. There is more room for your feet which becomes more noticeable on long drives. The 3.7 has a wider gearbox tunnel.
2. The speedo is in front of you. The 3.7 uses Mustang instruments & the speedo is off to the left. The 3.7 has so much power it is easy to slip over the limit.
But I do like the extra power & am ambivalent on the 5 link suspension. It lets you lay down the power but I am not sure it is better if you have anti tramp bars & a panhard rod. For me it is too much like a modern car. But each to his own.
I had a 1997 T16 engine plus 4. a very nice car but it misses the acceleration & speed of the Roadster. I prefer the Roadster as it is a great tourer. I haven't driven the 2019 +4.
Good luck , the right car will definitely find you.
It entirely depends upon the sort of motoring you do and you driving style.
If you want an effortless cruiser that will eat up the miles and remain unstressed and a more comfortable ride , then go for the Roadster. You will cruise in top (or 5th on a 6 speed box) without the need to swap cogs to get the best out of it.
If you love changing down gears as you rush into corners, and a more "sporty' feel then the +4 is likely to fit the bill better.
However I am very much with Richard here, the 5 link rear suspension on the later cars does tame that rear end, and give an even better ride. The 3.7 engined cars without it can be quite a handful to drive on (or close) to the limit I am informed.
As others have said , the only way you will know is to drive both , epsecially if you do it back to back over the same stretch of road (assuming they are at the same dealer of course , a tad tricky otherwise I accept)
Andy G
1999 +8 , Indigo Blue.
Drive both the Plus4 and Roadster. Morgans can be so different in colour, trim and specification and price would be a big factor to me. A nearly new Plus 4 at £40K is a good buy but If I had £50K for a Roadster then for £13K more you could have a new Plus Four.
I agree the right car will find you.
Rob
