7 members (linklaw, JohnHarris, sewin, Barkbark, Moggo, JMcL, TBM),
76
Old Book
Topics49,941
Posts838,615
Posts: 902 |
Fitted a new headlight bulb to my wifes runabout which has just had its MOT extended ![[Linked Image]](https://www.tm-img.com/images/2020/04/17/80681245_2993009517376100_9024236402161745920_n.md.jpg)
Rob
Posts: 27,864 Likes: 775
Posts: 27,864 Likes: 775 |
Posts: 8,728 Likes: 514
Posts: 8,728 Likes: 514 |
I wonder what indicator bulb you should try ?
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
I sense Bud you get the karma that is bodging. Doing things that are just acceptable but not perfect & leaving then an opportunity to improve later.
Bud 4/4 "Stanley"
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
A successful bodge repair of an essential PPE dispenser..... The toilet roll holder in our downstairs toilet. The arm holding the roll broke away from the wall plate. Investigation revealed a failed, c**p quality spot weld at the back of the wall plate, where a tab on the arm went through the wall plate. What to do? Can't visit my pal who has a welding machine. So, clean up the slot and tab, cut into the tab in 2 places and bend the two outer wings away, slightly. Apply epoxy resin to both parts and hammer the slot over the tongue: it was a really tight fit. ![[Linked Image]](https://www.tm-img.com/images/2020/04/18/Bodge-Repair.jpg) Time will tell if it is a bodge or a real repair!
Posts: 2,310 Likes: 5
Posts: 2,310 Likes: 5 |
Some gaps in your drill box Peter...time to replenish I think...I must do the same .
Good call Kev... Or shall I treat myself to a new set?
Posts: 3,383 Likes: 14
Posts: 3,383 Likes: 14 |
Nice use of an engineers vice mounted in a woodwork vice.
BR Colin (I used to mount mine like that in a B&D Workmate on Breakdown’s/Mobile Spanner Juggling ;-))
Drill bits do seem to wander don't they. Well done Peter. I like the vice tip.
Posts: 6,960 Likes: 117
Posts: 6,960 Likes: 117 |
Banski does home office work Is that his Russian brother?
