1 members (DJC), 292 guests, and 43 robots.
+8Rich 90
Topics49,841
Posts837,323
Christoph
Page 14 of 53 1 2 12 13 14 15 16 52 53
Fitted a new headlight bulb to my wifes runabout which has just had its MOT extended
Rob
John V6 Offline OP
Now that is good.
I wonder what indicator bulb you should try ?
Originally Posted by John V6
I sense Bud you get the karma that is bodging. Doing things that are just acceptable but not perfect & leaving then an opportunity to improve later.
guru budster
Bud
4/4 "Stanley"
Formerly known as Aldermog
A successful bodge repair of an essential PPE dispenser.....
The toilet roll holder in our downstairs toilet.
The arm holding the roll broke away from the wall plate.
Investigation revealed a failed, c**p quality spot weld at the back of the wall plate, where a tab on the arm went through the wall plate.
What to do?
Can't visit my pal who has a welding machine.
So, clean up the slot and tab, cut into the tab in 2 places and bend the two outer wings away, slightly.
Apply epoxy resin to both parts and hammer the slot over the tongue: it was a really tight fit.
Time will tell if it is a bodge or a real repair!
Some gaps in your drill box Peter...time to replenish I think...I must do the same .
Good call Kev...
Or shall I treat myself to a new set?
Nice use of an engineers vice mounted in a woodwork vice.
BR
Colin (I used to mount mine like that in a B&D Workmate on Breakdown’s/Mobile Spanner Juggling ;-))
BR Colin
John V6 Offline OP
Drill bits do seem to wander don't they. Well done Peter. I like the vice tip.
Originally Posted by The Austrian
Banski does home office work
Is that his Russian brother?
Best Regards
Lang may yer lum reek
