1 members (+8Rich), 388 guests, and 38 robots.
+8Rich 71
Adam12 69
Hamwich 53
9,215 Registered Users
Goodwood Speedmog 2d august
by Nick55 - 01/08/25 09:09 PM
Walnut Dashboard
by +8Rich - 01/08/25 06:24 PM
SORN
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
Pedal mod
Pedal mod
by RibbleAdventures, July 31
4/4 80 Anniversary Rex_Tulips
by Rex_tulips, July 31
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,372
Posts813,497
Members9,215
Page 3 of 4 1 2 3 4
Originally Posted by Budster
Originally Posted by Chris99
Aside from a dipstick what else can we do?
Fill up, zero the trip meter and fill up when it gets to around 200 miles smile
The “fill up and zero the trip” is the technique I’ve always used during the 15 years of owning my 4/4.
Thanks to Planenut for your answer, I’ll give a try. And yes, fill up and zero the trip is anyway what I was doing since day one 😇. And for me, being French, the usual result was 300km for 23/25 litres of fuel. Doesn’t it make senses forever body ? And what the real capacity of the fuel tank ? I’ve read anything from 30 to 45 litres !
Morgan 3 Wheeler Mandarine & Black interior
23/25 litres per 300km is about right and the tank is 40 litres.
Red Leader drive
On a Euro Tour of some sort, I generally use the 250 miles and Fill approach, although as Chris says, 200 is safer if you've been making good 'progress' on that tank of gas. A friend with a 5-speeder had to make a dash for Calais from deep in Belgium and had a gallon of juice strapped to the luggage rack just in case, as he thought he'd try to get to Calais in one hit. He cruised the Autoroute at about 4500rpm (85mph I guess) and ran dry at 295 miles. Just for reference.....!
Was your friends speedo calibrated or was it the normal 7% over reading R1NGA? If it was uncalibrated you can knock about 20 miles off the range, about 275 real miles, as against 295 M3W optimistic miles. I would be seriously looking for a refill at 250 (real) miles (my speedo is calibrated). It may come in handy if you are planning a long trip with minimal refuel stops.
Undoubtedly uncalibrated Ian, it was a very early car which he bought from Scotland (VM08 GAN) and we did a lot of miles together in 2013.
The OP has an erratic trip meter so that method is also unreliable. He does not say if the odometer reading also fluctuates, if not noting the reading on fill would give a proper distance though inconvenient.
M3W55 Offline OP
Thank you TimG for drifting us back! The trip ticks over accurately from its start-up reading; but that reading may be some way out from the previous shut-down figure. So I do not know which of the two is correct. Do I fill up in 40 miles or 70? It's that uncertainty that makes me anxious to fix it. Previous threads reporting this problem did not seem to reach a conclusion.
Take a note of the trip & odometer on switch off & again on start up. If odometer is consistent use that until you can get a fix for the trip meter. If still in warranty perhaps a replacement speedo would be the answer if its an internal electronic fault.
M3W55, did you ever get a resolution on your trip meter issue? I've got the same thing and it appears to be the same situation with the odometer. Any thoughts are appreciated.
2016 M3W
M3W55 Offline OP
I am afraid that I cannot remember whether it fixed itself. I have not had the vehicle for some time.
Page 3 of 4 1 2 3 4
