8 members (mph, Ruut Bianchi, Rovert, DavidR, JMcL, John V6, Ian Wegg, Camelot), 346 guests, and 32 robots.
Adam12 69
+8Rich 67
John V6 59
9,215 Registered Users
SORN
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
4/4 80 Anniversary Rex_Tulips
by Rex_tulips, July 31
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,367
Posts813,405
Members9,215
Rbt Aero8, Salmon, stevends
Occasionally when we have had to brake hard we always find the rear end drifting away, a thought is under hard braking the weight of the car travels more onto the front wheels and therefore more braking can be had on the front but only under hard breaking.
Our Morgans have the same pressure applied to all 4 wheels at all times, some have aded greater braking pads and discs to their front ends but under hard braking which proportion of braking is applied to each wheel?
We do need some tech gurus to perhaps explain more but it is possible to fit proprtion valves so under harder braking they come into play (under normal braking they are ineffective)
Some racers fit and tune these so that they perform say on left or right hand circuits ie they tune the left and right wheels to perform to track and car conditions.
see photos of part and web link. Web link here for valve brakes
[Linked Image]i by Robert & Ali Davies, on Flickr
[Linked Image]i (1) by Robert & Ali Davies, on Flickr
Triumph Herald 1969 13/60
Morris 1970
Interesting video explains all!
Love the accent too....
Morris 1970
Rob
In which of you 4 Morgans is this a problem?
The Morgan racers normally fit tandem master cylinders, with one feeding the fronts , the other the rears . They have a balance bar inside the car which can be operated during a (longer) race to allow adjustment. This is by far the best solution.
Personally I would not really want to fit a load proportioning valve , as I don't feel the need , but I think many tin-tops have/had them as standard before the days of ABS etc.
If the back steps out under braking , just catch it , and remember to adjust the rear brakes when back at the workshop. (later cars have the auto adjusters on the rears of course)
Andy G
1999 +8 , Indigo Blue.
No experience of these on Morgans, but I have used them on 90's VWs when upgrading the rear brakes to discs and needing to ensure that clamping force stayed at about 40% of the fronts under hard braking. We used to call them 'in line pressure restrictors' and would set a car up by putting it on 4 space-saver tyres and driving round a yard (at a moderate speed rather than track speeds) and braking hard with some front steering angle to find the adjustment point at which you can brake the hardest but keep the back end true.
Some guys did use a true 'proportioning valve' for front/rear brake pressure adjustment, but as I always understood that you'd have to swap your diagonally split circuit for a F/R set up, I thought this was risky on a road car.
Ps - love the guy in the video. He's found his calling in Life....
Stuart
You can vary brake pressure to the rear by using different dia slave cylinders, I do not think bias/balance bars are allowed for the MOT they have to have the locking nut on the balance bar welded.
But if you balance correctly then it does not matter once it is welded to stop further adjustment.
David Byrne
Rob,
all my Mogs would lock up on the rear on really hard braking. But it had to be really hard. Do you brake that hard often to need to compromise the rear braking?
2025 MG ZS EV aka Trigger
David Byrne
Incorrect, David
A balance bar/bias pedal box is not an MoT fail irrespective of whether the locking nut is welded or not.
My stage and road rally cars used to sail through the MoT test's with bias pedal boxes fitted.
Used a brake proportioning valve on a Group N 205 GTI and that was because the hydraulic handbrake was a bit fierce on the gravel. Never needed it on tarmac.
Getting back to the matter in hand, I dont think they are needed on a Morgan.
Arwyn
Brake problems are often counterintuitive as you focus on what's happening as opposed to what's not. As in the statement "all my Mogs would lock up on the rear on really hard braking".
The problem could in reality be "I can't get the front brakes on hard enough" - in which case the solutions go down a completely different route.
Ok all looks like it sounds better left alone, its just that on the only 2 emergency stops I have ever performed on both occasions the back slipped first and great pool of smoke.
I would hesitate to say that its prefferable for the back to slip first as one has some control unlike if the fronts slipped! When it would be a different story.
Morris 1970
Rob, either your fit a Citroën CX brake/suspension system.. hide or you could actually 'take off' an extra half inch of the brake lining on the shoe that 'meets' the rotation of the drum. It takes away some of the 'self-energizing' effect on that shoe. Originally that lining is already shorter. It will reduce brake efficiency slightly but it will probably only be noticeable during hard braking.
'Try this at your own discretion'
-99 4/4, 1.8 Zetec, Indigo Blue, 2-seat, Suplex RS
-04 Citroen Pluriel, 1.6 Sensodrive, Met Orange
