7 members (RichardV6, Strathaven, Alan Patterson, Simon, DickJ, JohnHarris, TBM), 225 guests, and 67 robots.
+8Rich 73
DaveW 52
Topics49,867
Posts837,619
Moggo
Page 1 of 4 1 2 3 4
#639394 22/05/20 04:33 PM
BigLes Offline OP
I have an oil leak on my diff (Salisbury 7HA axle) and after a bit of investigation I have discovered it's coming from the right hand one of the two what look like Allen screw heads (circled). As you can see the oil is trickling down the diff casing onto the drain plug.
Does anyone know if these are Allan screws and can be safely removed for cleaning up and maybe re-fitting with thread seal? Or are they something else?
Roadster 3.7
Plus 4 110 Anniversary
Plus 4 Fiat TC
BigLes #639398 22/05/20 04:37 PM
Those are welds...
They hold the tubes into the pigs head
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
BigLes #639400 22/05/20 04:44 PM
BigLes Offline OP
Sounds like a major job to fix then?
Roadster 3.7
Plus 4 Fiat TC
BigLes #639432 22/05/20 05:55 PM
Maybe epoxy them.
73 4/4 "Henry A"
53 +4 Flat Rad "Pug"
84 Citoen 2CV Spec "BeBe"
60 MGA
https://morgan34.org/
PaulyG #639459 22/05/20 06:57 PM
BigLes Offline OP
Originally Posted by PaulyG
Maybe epoxy them.
I don't think it would take as there is oil seeping out, and if I drain the diff down there will still be oil in the crack.
I was thinking maybe a spot weld on the outside - maybe with the diff in situ on the car? Obviously shielding the fuel tank!
Roadster 3.7
Plus 4 Fiat TC
BigLes #639461 22/05/20 06:59 PM
Good old araldyte?
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
BigLes #639511 22/05/20 09:43 PM
Never come across them leaking from the spot welds before. In theory they shouldn't leak because they are a plug weld.
One thing you could check is whether the small breather hole (3mm) in the axle tube is blocked which is causing the axle to pressurise.
Kind regards
Arwyn
BigLes Offline OP
Kind regards
Arwyn
I have checked that and it is clear, just to be sure I also put a 2mm drill in and gently turned it by hand.
Roadster 3.7
Plus 4 Fiat TC
BigLes #639536 23/05/20 07:04 AM
TBM Online Content
I hate having to refer people to a specialist rather than offer advice, however I'm stumped on this one.
These guys are brilliant and went above and beyond with my axle repairs. Gave lots of advice and help and only charged for a fraction of what they did.
JB Engineering
BigLes #639538 23/05/20 07:06 AM
TBM Online Content
However, if the solution is just to seal them. JB Weld is my recommendation.
Page 1 of 4 1 2 3 4
