1 members (Cat302), 225 guests, and 75 robots.
+8Rich 76
Topics49,863
Posts837,544
Page 3 of 5 1 2 3 4 5
Originally Posted by 06032
For what its worth, mine has the cats and first two baffles removed, the third (rear) is intact and it has a Stealth intake. Otherwise stock pipes. No remapping. The car runs like a cool-headed champ throughout the RPM range and the sound is a deep, pleasing baritone. I've been thrilled with the result and the engine is a happy camper.
Excellent information👍
Can someone direct me to the thread showing how to remove the cats. Remember reading about it but was a while ago. Also how to remove the first two baffles in the stock pipes.
Thanks.
06032, could you post a video demonstrating the sound of your exhaust? Would appreciate it a lot. Not entirely satisfied with the sound from my Aero Racing Stage One pipes. You describe the exhaust sound I’ve always wanted.
Thanks.
Try these:
http://www.talkmorgan.com/ubbthreads.php/topics/269419/Wrapped_headers_removed_cats_a
http://www.talkmorgan.com/ubbthreads.php/topics/422359/1
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
Those were the ones I previously read.
Very helpful.
Thanks.
0
Sportser - send me a pm with your phone number. This will be easier and faster if I call you with it running.
'17 M3W:
'08 Ural Gear-Up
Pm sent.
Thanks.
I have had the Factory/Aero racing Stage One kit fitted. In my opinion much neater than other makes available. Only problem is cracking as mentioned in Truckin-ons post. So far had 2 replaced under warranty! If they go again will do a mod similar to what he had done but really shouldn't have to.
M3W 'The Mapmog' Built June 2015
Sorry Lightspeed, I missed your post. Stage 2 cams with remapped ECU were installed together so haven’t tried with original ECU.
Bluesman at some point I might try adding an octane booster to see if pinging decreases. I tried in the past but can’t remember if was done before Stage 1. At that point it didn’t seem to do anything.
Did you try the Stage 2 cams without the ecu mapping?
The standard (locked) ECU adaptive maps cannot manage the Stage 2 (569) cams, it exceeds the maps limits. The information I had from the very knowledgeable dyno operator, at Krazy Horse in the UK, was that you need an unlocked and set up ECU mapping for anything more than standard cams, a free flowing exhaust and filter (Stage1)
