0 members (),
395
74
Topics49,867
Posts837,614
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
For what its worth, mine has the cats and first two baffles removed, the third (rear) is intact and it has a Stealth intake. Otherwise stock pipes. No remapping. The car runs like a cool-headed champ throughout the RPM range and the sound is a deep, pleasing baritone. I've been thrilled with the result and the engine is a happy camper. Excellent information👍
Posts: 775 Likes: 33
Posts: 775 Likes: 33 |
Can someone direct me to the thread showing how to remove the cats. Remember reading about it but was a while ago. Also how to remove the first two baffles in the stock pipes.
Thanks.
06032, could you post a video demonstrating the sound of your exhaust? Would appreciate it a lot. Not entirely satisfied with the sound from my Aero Racing Stage One pipes. You describe the exhaust sound I’ve always wanted.
Those were the ones I previously read.
Very helpful.
Thanks.
Posts: 265 |
06032, could you post a video demonstrating the sound of your exhaust? Would appreciate it a lot. Not entirely satisfied with the sound from my Aero Racing Stage One pipes. You describe the exhaust sound I’ve always wanted. Sportser - send me a pm with your phone number. This will be easier and faster if I call you with it running.
'17 M3W: '08 Ural Gear-Up
Posts: 237 Likes: 10
Posts: 237 Likes: 10 |
I have had the Factory/Aero racing Stage One kit fitted. In my opinion much neater than other makes available. Only problem is cracking as mentioned in Truckin-ons post. So far had 2 replaced under warranty! If they go again will do a mod similar to what he had done but really shouldn't have to.
M3W 'The Mapmog' Built June 2015
Sorry Lightspeed, I missed your post. Stage 2 cams with remapped ECU were installed together so haven’t tried with original ECU.
Bluesman at some point I might try adding an octane booster to see if pinging decreases. I tried in the past but can’t remember if was done before Stage 1. At that point it didn’t seem to do anything.
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
Did you try the Stage 2 cams without the ecu mapping?
The standard (locked) ECU adaptive maps cannot manage the Stage 2 (569) cams, it exceeds the maps limits. The information I had from the very knowledgeable dyno operator, at Krazy Horse in the UK, was that you need an unlocked and set up ECU mapping for anything more than standard cams, a free flowing exhaust and filter (Stage1)
