6 members (linklaw, James B W, TalkMorgan, MJF, John Winn, John07), 229 guests, and 11 robots.
John V6 79
+8Rich 69
DaveW 67
Luddite 56
9,203 Registered Users
Supermax sprocket
Morgan 3 Wheeler song
by Dutch - 21/07/25 12:31 AM
by Oskar - 20/07/25 04:13 PM
Goggle eyed
by Roady - 19/07/25 06:16 PM
by t50 - 19/07/25 12:07 PM
Lions Tour
by OZ 4/4 - 19/07/25 11:55 AM
Morgan rebuild on Facebook
by TBM - 19/07/25 10:50 AM
Topics48,337
Posts812,913
Members9,203
toitoine
#641467 31/05/20 04:16 PM
Viper Offline OP
Sir S1'a'lot
Sir S1'a'lot
Hood down and frame strapped down but rattled like mad
Do I recall seeing a sort of rubberised separation implement to stop the bars vibrating against each other. I think similar to some treacles use to separate their toes while they paint their nails............so I’ve heard innocent
2002 Aero 8 S1
2023 Plus 4 (woman’s)
Viper #641473 31/05/20 04:58 PM
Had same problem. Cut down some self adhesive foam strips (circa 3mm thick) into thin strips and stuck between frame poles. Now silent.
DJWuk #641478 31/05/20 05:12 PM
Viper Offline OP
Sir S1'a'lot
Sir S1'a'lot
Perfect. Might be my only option.
2002 Aero 8 S1
Viper #641499 31/05/20 06:29 PM
Depends on the car. It could be better to drill out the rivets & replace with nuts & bolts.
2025 MG ZS EV aka Trigger
Viper #641573 01/06/20 08:59 AM
Is an easy up or trad hood? Different solutions. Mine is a trad hood with drop pivots and solved it eventually by trial and error. Tying down, cushioning and making sure pivot securing bolts were tight.
Viper #641587 01/06/20 10:31 AM
Viper Offline OP
Sir S1'a'lot
Sir S1'a'lot
It’s a trad hood frame. Not easy style or an a cantilever.
It’s nut and bolted. The bars vibrate against each other
2002 Aero 8 S1
Viper #641607 01/06/20 02:01 PM
Yes this can drive a person mad. I have a system of saddle leather pads held with double sided tape placed where the stays bang together and velcro straps to hold it all tightly so that the hood bounces 'as one'. Once the hood is folded the velcro straps get tied around the frame stays on each side. I had a maddening rattle from one of the washers between two stays, for this I hammered the rivet tighter and that worked. My 4 seater is not as silent as a Roller but it is so much more quiet that it was.
Kevin
2009 Morgan Plus 4 - 4 seater
2015 Subaru Forester 2.0ltr
Viper #641958 03/06/20 12:52 PM
Yes a strip of Velcro in and out of the frame plus tightening down with the standard leather straps as fitted to the car, seems to work for me. The cantilever drop pivots that I have also add another tightening dimension once the hood is dropped. If you haven't't got the drop pivots, worthwhile fitting. Circa £70 from John Taylor.
Viper #642357 05/06/20 11:53 AM
Who needs a hood? Dumped mine plus the frame in 1987!
1980 +8 Blue
And a few others
Stephen
I think I am the winner: 400000 Km without a hood -on motorbikes in summer and winter!
We bougt the 4/4 because it HAS A HOOD (for bad weather) ;-)
Each on his own!
