7 members (RichardV6, Tresco, Morganmike, MJF, yobtaf, Chris Cosher, Gonze),
230
80
Topics49,870
Posts837,668
Posts: 1,105 Likes: 17
Posts: 1,105 Likes: 17 |
Hi, I want to drill some holes in the inner wings, what drill bit do you need to stainless steel?
I tried the normal metal ones as they are hopeless
Thanks Will
Posts: 1,799 Likes: 4
Posts: 1,799 Likes: 4 |
I've used these DeWalt bits with some success but not cheap. The flute angle is a bit aggressive and tends to pull through in thin steel so make sure there is nothing vulnerable on the other side of the wing. Brake pipes, wires, hoses etc. DeWalt drill bit
Bob
Posts: 53 |
Use as low a drill speed as possible -
Posts: 1,616 Likes: 143
Posts: 1,616 Likes: 143 |
One with 5-8% cobalt content
Plenty of lubricant as well, currently using Rocol RTD spray or Trefolex
Arwyn
Posts: 938 Likes: 19
Posts: 938 Likes: 19 |
Arwyn
I use Rocol RTD (reaming, tapping, drilling) now but in the machine shop in the 70’, Trefolex was used and it had a peculiar smell about it which I liked.
Posts: 287 Likes: 8
Posts: 287 Likes: 8 |
Any descent HSS drill will do considering the small amount of material you will be removing, but you do need to give the cutting edges 0 degree rake by grinding the faces of the lips this will reduce the amount of snatch you will get when drilling through. It would be best if you could clamp a piece of scrap plate behind where you are drilling through, this will help. P.S. don't buy something cheap from B&Q get a Dormer drill
Owen "bilibib" 1982 4/4 Twin Cam, Royal Ivory 1932 Super Sports, Duo tone(two tone)Green
Posts: 8,684 Likes: 493
Posts: 8,684 Likes: 493 |
Helps to start small with a pilot hole & go up in sizes, the cone shaped & stepped cone drills are good on thin panels too
Posts: 220 Likes: 4
Posts: 220 Likes: 4 |
These have never failed me yet. Had them for years. https://www.drillallsales.com
Posts: 2,519 Likes: 320
miles of smiles Talk Morgan Expert
Posts: 2,519 Likes: 320 |
Presto of Sheffield do a range called Hi-nox especially for Stainless. It features a wider cutting angle, a tighter helix and a stubbier flute, works very well. If you struggle to find them locally PM me and I’ll sort you out with some.
Posts: 5,466 Likes: 171
Posts: 5,466 Likes: 171 |
+1 You really don’t want to generate any heat or the stainless steel work hardens and wrecks the bit. I learned this the hard way. Set your drill on its very slowest setting and be patient.
