SORN
New
Topics48,368
Posts813,412
Members9,215
Posts: 1,032 Likes: 10
Posts: 1,032 Likes: 10 |
Hi, I want to drill some holes in the inner wings, what drill bit do you need to stainless steel?
I tried the normal metal ones as they are hopeless
Thanks Will
Posts: 1,799 Likes: 3
Posts: 1,799 Likes: 3 |
I've used these DeWalt bits with some success but not cheap. The flute angle is a bit aggressive and tends to pull through in thin steel so make sure there is nothing vulnerable on the other side of the wing. Brake pipes, wires, hoses etc. DeWalt drill bit
Bob
Posts: 53 |
Use as low a drill speed as possible -
Posts: 1,578 Likes: 105
Posts: 1,578 Likes: 105 |
One with 5-8% cobalt content
Plenty of lubricant as well, currently using Rocol RTD spray or Trefolex
Arwyn
Posts: 913 Likes: 10
Posts: 913 Likes: 10 |
Arwyn
I use Rocol RTD (reaming, tapping, drilling) now but in the machine shop in the 70’, Trefolex was used and it had a peculiar smell about it which I liked.
Posts: 281 Likes: 3
Posts: 281 Likes: 3 |
Any descent HSS drill will do considering the small amount of material you will be removing, but you do need to give the cutting edges 0 degree rake by grinding the faces of the lips this will reduce the amount of snatch you will get when drilling through. It would be best if you could clamp a piece of scrap plate behind where you are drilling through, this will help. P.S. don't buy something cheap from B&Q get a Dormer drill
Owen "bilibib" 1982 4/4 Twin Cam, Royal Ivory 1932 Super Sports, Duo tone(two tone)Green
Posts: 7,910 Likes: 242
Posts: 7,910 Likes: 242 |
Helps to start small with a pilot hole & go up in sizes, the cone shaped & stepped cone drills are good on thin panels too
Posts: 216 Likes: 2
Posts: 216 Likes: 2 |
These have never failed me yet. Had them for years. https://www.drillallsales.com
Posts: 2,336 Likes: 150
miles of smiles Talk Morgan Expert
Posts: 2,336 Likes: 150 |
Presto of Sheffield do a range called Hi-nox especially for Stainless. It features a wider cutting angle, a tighter helix and a stubbier flute, works very well. If you struggle to find them locally PM me and I’ll sort you out with some.
Posts: 5,233 Likes: 126
Posts: 5,233 Likes: 126 |
+1 You really don’t want to generate any heat or the stainless steel work hardens and wrecks the bit. I learned this the hard way. Set your drill on its very slowest setting and be patient.
