3 members (cerealsurfer, RedThree, Zach), 369 guests, and 46 robots.
+8Rich 91
Topics49,841
Posts837,316
#642527 06/06/20 07:38 AM
Mats Offline OP
Hi everyone, I wonder if anyone has experience changing steering rack gaiter on a Roadster 3.7. So it's a Quaife rack and it's on the passenger side so it shouldn't be that hard, or 😜
Mats
2015 Roadster 3,7 Sports White
1953 BSA B33
2012 Freelander 2
There was an earlier thread recently on this. It might be worth a look
http://www.talkmorgan.com/ubbthreads.php/ubb/showflat/Number/637168/Searchpage/1/Main/37117/Words/%2Bsteering+%2Bgaiter/Search/true/re-steering-rack-weeping#Post637168
Just had both mine replaced under warranty. Although I obviously didn't do the work myself, I understand both rack clamps have to be removed and the steering column connection to rack if replacing drivers side. The new gaiter(s) can then be slid over and secured. Remember to replace any of the thin grease that may have escaped from split gaiter. The trick is to re-secure everything in the original position so that steering wheel is correct position for straight ahead. Tracking shouldn't be affected as you don't need to touch track rods. Both mine were changed in under two hours.
I had already obtained a pair of universal fit gaiters and offered them to dealer to use if they were found to be superior to OE. Was told they found them more supple and fitted mine giving me their OE ones as spares.
Originally Posted by John V6
There was an earlier thread recently on this. It might be worth a look Link to earlier thread
Hope you dont't mind the suggestion John, but if you click on this icon [Linked Image] top bar in Full Editor mode it offers to accommodate your link with title of your choice and display as above which makes it instantly clickable. Just make sure the http:// prefix is not put in twice!
Thanks Richard you learn something everyday.
Mats Offline OP
Hi again, I think and hope it is enough to dismantle the steering clamp on the passenger side to replace the gaiter on that side.
Mats
1953 BSA B33
2012 Freelander 2
Richard, I suspect one of mine is just starting to weep again & I'm suspicious of the OE quality
Could you kindly let me have the details of the alternative you used
I had one split just outside of warranty ( late 2015 car) - 1 was stiff and brittle ( split) the other was supple and ok. I went down the universal route as mentioned by Richard - I fitted it myself and it wasn't a bad job to do. Just a case of take time ( and photos to be sure I guess) - its simply dismantling and re-assembly. It surprised me how well it all went - well within the scope of a keen DIY Morgan owner.
I used a "first line" universal kit Part number FSG4000. About £10 for 2 on ebay.
I took my plus4 to a local garage for a new steering gator. I think he charged me £120 for a universal gaitor, labour and an MOT. So I suspect if you have a good local garage near you they would happily do it for a reasonable cost.
It's in the post above Jon - car builder solutions.
Just remembered they also offer a version with a grease nipple to top up lubricant.
