5 members (Massi_torino, James B W, TBM, MJF, Simon), 145 guests, and 100 robots.
+8Rich 74
DaveW 52
Topics49,867
Posts837,628
Moggo
Peter it looks to me the font bolt is where the rear one should be. If you look on my photos the centre of the light is inline with the centre of the wheel.
Yes. I agree. It was done by the dealer but I think they made a mistake. Once drilled it is too late banghead
BobJ Offline OP
A pair of reproduction Lucas 1130's duly ordered from a reputable supplier. They weren't cheap but assumed that they wouldn't be a dear as Morgan's own and probably the same thing anyway - body wise as I went for the glass lens rather than plastic.
However....
The base of the body is flat. The wings where the light should go are curved. There is a rubber gasket supplied but that is simply to prevent metal on metal contact - not to mask any shape differences between the two which results in the gap shown in the photo's. And in any case, the fitting bolts certainly aren't man enough to start altering either the form of the light base or wing irrespective of the paintwork damage that may cause.
Can anyone with factory fitted or MMC dealer supplied 1130 wing mounted side lights shed any light (no pun intended) on whether their version have a curved base to the lights or are they flat as well?
Currently in a bit of a quandary and debating sending these lights back.
2017 4/4 80th Anniversary
Originally Posted by BobJ
I would offer the idea of a piece of compressible neoprene cut to fit between the light and the body, might be good enough. Mine are the same model as that shown and are flat along the underside, they compress the gasket just enough to create contact along most of the surface of the wing.
Kevin
2009 Morgan Plus 4 - 4 seater
2015 Subaru Forester 2.0ltr
Well here are mu original lights. They look to me very similar. I used flash so that is why the colours my look odd.
BobJ Offline OP
Thanks for your help gents. I think I’ll go to AW and see what they have to say before considering getting busy with the Black & Decker....
