Topics49,847
Posts837,391
Posts: 580 Likes: 2
Posts: 580 Likes: 2 |
I am just about to fit my second pair of Excelsior Comp H in 4.00 x 19. The first set lasted around 4000 miles, which is two years use for me. I live in a mountain village in the south of France during the summer (usually but been "Boris'd" this year). Both roads leading up to the village at around 2500 feet altitude, have multiple hairpin bends, so good adhesion very desirable. The original Avons were horrendous, tucking under and very sudden transition into high slip angles. The car was transformed by the Excelsiors. They seem slightly less prone to storage flats than the Blockleys, which I have used on other cars but that may be down to the low weight of the M3W. The inevitable corollary is that steering is a little heavier, especially as they get worn but they also reduce kick back compared with the Avons and that was especially noticeable before the steering comfort kit was fitted on my early Mk.1 car (March 2012).
Wilson
Posts: 57 |
yes, will do...working at the moment but will check for you
Rob, did you have a chance to check the tire size by chance? Thanks!
Posts: 1 |
I had 18 inch wheels made and fitted 18 inch Continental tyres which are TUBELESS. Much safer tyres , and more clearance round the guards. Geoff
Posts: 1,016 Likes: 2
Posts: 1,016 Likes: 2 |
Although a little further off topic, has anyone tried the 4.50x19 Blockley or Excelsior tyres? Likely to be made to fit under the mudguards I'd have thought, only 1kg heavier than the 4.00x19 (I asked Blockley), but should gove a useful improvement in stability and grip. Might give a pair a go at some point, but just in case someone had tried already....?!
Posts: 79 |
I'm running Avon road riders on 19 inch on mine. very grippy indeed
1928 Superaero Jap 3 wheeler 2013 5 speeder 3 wheeler
Posts: 423 Likes: 2
Posts: 423 Likes: 2 |
Have about 7000 miles on my Blockleys with plenty of tread left
Lance 1981 Plus 8 2016 Three Wheeler 2022 Corvette Stingray Convertible z51
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
