6 members (John Winn, TBM, BobtheTrain, Craig Jezz, TalkMorgan, GrumpyPa), 346 guests, and 87 robots.
Sagging Hood
Topics49,859
Posts837,478
Page 2 of 7 1 2 3 4 5 6 7
If you have got long legs a seat elevation may be useful. and you get an additional storage area under the seat
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
Hannes, that's the most unusual use of joist hangers I've ever seen grin2
I believe you could say he is hanging ones joist, ooooorrrr wondering where that rattle and squeak is coming from.
The picture is not from my car but I had a similar construction with a tight fit setting and there was no rattle at all from the seats.
Hannes
What did you use? I was thinking a block of wood would do the same thing.
A length of wood is cheap & experiment to find size thats most comfortable for you. I went for 50 x 50mm & eventually fastened it to seat seat base with angle brackets.
I am fortunate to be short and not need a block under the seat but I did put a block a few inches behind the pedals on the floor to act as a foot rest for the clutch leg. No screws or bolts, just wedged in place and it works fine.
V
V
Thank you all so much for the great info and you have given me lots to ponder. Plan to put took kit together over the next few weeks. Help all round much appreciated.
I think you and I are about the same height, I found a 4" cushion really helps me see the front of the car and have a bearing where I am going
Rodger
2004 Plus 8 (wife's)
I am 5’6” and found the addition of fender lamps let me know the right front location.
