11 members (scortroadster, Gordon D, Dek, Paul F, SCX358G, Themorganeer, deano, RedThree, CooperMan, Mats, DaveW),
309
65
Topics49,860
Posts837,525
Posts: 5,017 Likes: 3
Posts: 5,017 Likes: 3 |
If you have got long legs a seat elevation may be useful. and you get an additional storage area under the seat ![[Linked Image]](https://up.picr.de/38921767of.jpeg)
Posts: 8,677 Likes: 491
Posts: 8,677 Likes: 491 |
If you have got long legs a seat elevation may be useful. and you get an additional storage area under the seat ![[Linked Image]](https://up.picr.de/38921767of.jpeg) Hannes, that's the most unusual use of joist hangers I've ever seen
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
I believe you could say he is hanging ones joist, ooooorrrr wondering where that rattle and squeak is coming from.
The picture is not from my car but I had a similar construction with a tight fit setting and there was no rattle at all from the seats.
What did you use? I was thinking a block of wood would do the same thing.
Posts: 1,947 |
What did you use? I was thinking a block of wood would do the same thing. A length of wood is cheap & experiment to find size thats most comfortable for you. I went for 50 x 50mm & eventually fastened it to seat seat base with angle brackets.
I am fortunate to be short and not need a block under the seat but I did put a block a few inches behind the pedals on the floor to act as a foot rest for the clutch leg. No screws or bolts, just wedged in place and it works fine.
Posts: 20 Likes: 2
Posts: 20 Likes: 2 |
Thank you all so much for the great info and you have given me lots to ponder. Plan to put took kit together over the next few weeks. Help all round much appreciated.
Posts: 1,889 Likes: 16
Posts: 1,889 Likes: 16 |
I think you and I are about the same height, I found a 4" cushion really helps me see the front of the car and have a bearing where I am going
I think you and I are about the same height, I found a 4" cushion really helps me see the front of the car and have a bearing where I am going I am 5’6” and found the addition of fender lamps let me know the right front location.
