1 members (+8Rich),
302
74
Topics49,870
Posts837,668
Posts: 2,780 Likes: 5
Posts: 2,780 Likes: 5 |
Here is one to watch.. the wiring loom on my GDI was perilously close to the Cat and after a run was red hot.. it was less than 10mm away and only held by a rather feeble plastic P clip. I moved it away, fitted a better clip, put some heat wrap around it and also made up a small heat shield.. ![[Linked Image]](https://www.tm-img.com/images/2020/07/11/15362979-0831-47F3-B48A-7E0B19E314D7.jpg)
Posts: 7,342 Likes: 49
Posts: 7,342 Likes: 49 |
Posts: 697 Likes: 7
Posts: 697 Likes: 7 |
I’ll have to check mine. Thanks
Posts: 27,816 Likes: 749
Posts: 27,816 Likes: 749 |
Posts: 192 Likes: 3
Posts: 192 Likes: 3 |
Just checked mine and yes it is the same so wrapped some reflect-cool around the loom.
Ian
2019 +4 110 Anniversary Bentley Velvet Red.
if you can you need to move the clip to another location. I put a longer allen screw in to replace one of the wing bolts and put the clip on that with a nut to hold. Also there are a couple of holes in the inner wing panel that I used to bolt a small length of angle ally and riveted plate to make a heatshield. It gets very hot around that area!
Posts: 793 Likes: 144
Posts: 793 Likes: 144 |
Interesting. Checked mine to find the loom is roughly where you have moved yours to. It looks as if it has always been there. Well worth checking though!
Chris
2015 Plus 4 Silverlake Blue (2014 3.7 Roadster Crystal Blue) (2012 4/4 Sport Black)
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
Have a look at motorsport suppliers like Merlin and Demon Tweeks. They sell a variety of heat shielding products that include some specially for wiring. Agriemach is another supplier.
