7 members (SteveT, Tom Sayles, IcePack, mph, Morganmike, gomog, Nickplus4),
274
79
Topics49,872
Posts837,704
Posts: 194 Likes: 5
Posts: 194 Likes: 5 |
Morning all, This may sound silly but does any one know what size spanner is needed for brake bleed nipples?
Thanks chaps......
Why is there only one monopolies commission??
Rob B.
Posts: 3,383 Likes: 14
Posts: 3,383 Likes: 14 |
Not a silly question at all, the larger ones were always 7/16AF and the smaller ones (like the rears on a mini) were 5/16AF.
Given changes in manufacture and perhaps more importantly the location of manufacturers they could well be Metric.
I use a ring or ring end of a combo whenever possible, soak in release oil the day before can save grief, they only need nipping up but some murder the things!
BR Colin
Posts: 6,672 Likes: 438
Posts: 6,672 Likes: 438 |
On my 1972, a 10mm spanner fits perfectly. I have a ' bleed nipple' spanner - almost a full ring but has a cut out to slot over a bleed pipe.
Update...,
If you like kit search eBay for item number 402312024394
Posts: 27,817 Likes: 749
Posts: 27,817 Likes: 749 |
Get a bleed nipple spanner it makes it easier.
Posts: 12,263 Likes: 320
Posts: 12,263 Likes: 320 |
Get a bleed nipple spanner it makes it easier. Somehow I've never got around to getting one of these. I use a ring spanner or socket to crack the bleed nipple loose but not open, then fit the bleed pipe and use an open-ender on the nipple during the bleeding process, then once the pipe is off I snug down with a ring - but as Colin points out, they don't need a big heave.
Posts: 194 Likes: 5
Thanks chaps your input is great as normal, I have a bleed nipple spanner on order. One last question on this: Should I be unlucky enough to break a nipple what would be the size of the replacement (I didn't know that so many sizes were out there) I have a 1997 +4. Thanks again for your help
Rob B.
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
On my 1972, a 10mm spanner fits perfectly. I have a ' bleed nipple' spanner - almost a full ring but has a cut out to slot over a bleed pipe. . Surprised at that normally find a 11mm nearer to a 7/16.
My rear bleed nipples are 3/8 Unf with a 10mm hex head. I have 4 pot Hispec on the front, not sure of the thread size but again the hex head is 10mm.
Posts: 28,904 Likes: 352
Posts: 28,904 Likes: 352 |
Update...,
If you like kit search eBay for item number 402312024394 That's rather tasty!
