1 members (SteveMerch), 303 guests, and 39 robots.
Adam12 69
+8Rich 67
John V6 60
9,215 Registered Users
SORN
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Pedal mod
Pedal mod
by RibbleAdventures, July 31
4/4 80 Anniversary Rex_Tulips
by Rex_tulips, July 31
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,368
Posts813,421
Members9,215
Rbt Aero8, Salmon, stevends
norman Offline OP
All,
I need some advise on how best to have a Morgan dealer (or equivalent), or Malvern factory, to add power steering to my new 110 Anniversary Plus 4. It would be an aftermarket add on, and I assume that since there is no other way to adjust steering stiffness on the existing car, it is possible to add power steering on the aftermarket. The steering is a lot stiffer than I anticipated. I would appreciate any help or past experience on how best to get this done (I am not a mechanic so I personally could not do it), and the typical costs I should expect. Thank you so much for any tips or ideas!
Norman
Brighton
Williams I think sell them
2025 MG ZS EV aka Trigger
TBM Offline
Don't know about adding power steering but in the short term I would suggest the following - make sure all the front end linkge is greased up properly, try a couple of extra psi in the tyres, fit a larger diameter steering wheel.
Good advise above and get the tracking checked - I know Richard Thorne has fitted quite a few cars with it RTCC.
My Plus 8 with a well lubricated standard front suspension has never appeared heavy, it sounds as if something is amiss or maybe you need a little longer to become accustomed to the car compared to your 4 wheeled sofa daily driver.
2009 4/4 Henrietta
1993 Connaught Green +8 prev
I would advise contacting Cain at Wolf Performance as he has all the kit and experience to fit Hardchrome Kingpins, spiral grooves PB bushes and steering roller bearings, all of which will make a big difference and may solve the problem for you. Just one tight kingpin makes a dramatic difference to steering input loads.
BR
Colin
BR Colin
How many miles has the car done?
If it is less than 2K i would wait until it has as the steering does need to bed in and will free up a lot after a couple of thousand miles.
I have thought about this for my Roadster but decided not to (appropriate greasing etc). Have a look at EZ power steering, which I think some owners have fitted. I think Williams fit it.
TBM Offline
I tried power steering on a roadster demonstrator and I was not very impressed. Without was much more direct and a better feeling to the road. I would not recommend it.
2018 +4, persian blue
I have a 2016 3.7 Roadster which had the factory fitted power steering as standard. I found the steering too light with little “feel” to the extent that I was never comfortable driving the car in a spirited manner! Having had three previous Morgans, 2 x Plus 4s and a Plus 8, none of which had or needed power steering I had the power steering on my Roadster taken off.
I then took the car to New Elms who modified the front suspension for me, fitted hard kingpins and the transformation was amazing. I now have much better steering feedback and whilst a little heavy at parking speeds once on the road or track it is light, positive and a delight to drive.
I agree with the comment above about giving it a couple of thousand miles if the car is new but, in the opinion of New Elms, few Morgan left the factory properly set up and getting the springing, camber etc properly sorted is essential if you want to get the best out of the car.
Having said all of the above, if you really want to go down the power steering route I would personally go for the mechanical hydraulic system rather than the electric option as fitted by the factory. This company are the specialists - https://www.classicdrivingdevelopment.co.uk/gal.asp?gID=26
Good luck!
3.7 Roadster
Porsche 964 C2
JCW Mini Cooper S Cab
BMW F750GS
+4 4 1995-2002 / LM 62 +8 2002-07
