Topics49,838
Posts837,296
Posts: 398 Likes: 1
Posts: 398 Likes: 1 |
I had a similar issue, could start car without ignition key being turned.
Associated with this were frequent fuse failures.
Auto electrician found too many circuits feeding through Multiple fuses so did a bit of rewiring to a separate Set of upgraded fuses.
Stopped all mystery failures and no longer can start without key.
May pay to see if you have any blown fuses, I could lose one with no issues. Can’t remember which ones they were. Age thing
Nigel
Posts: 2,033 Likes: 23
Posts: 2,033 Likes: 23 |
No immobiliser, Feb. 2013 Thanks, early car then and similar to mine! I had a similar issue, could start car without ignition key being turned.
Nigel Can I ask what year your car is, and whether it has the immoboliser? Hoping to find a common link if I can..
Aero 8 GTN #11
Posts: 398 Likes: 1
My car is April 2020 and yes it does have the immobiliser. Although I have since then immobilised the immobiliser
Thanks - was yours related to the hazard switch or was it just a live start button?
Aero 8 GTN #11
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
My car is April 2020 and yes it does have the immobiliser. Although I have since then immobilised the immobiliser You have just knocked 8 years of the age of your car Nigel  . I remember looking at your cars colour when I was ordering mine and wanted to see it but it was rather a long way to go for a look.
Posts: 398 Likes: 1
Damn those fat fingers and not wearing glasses!
You are so right, should have been 2012!
Speaking to the factory it sounds like this is a known fault, something to do with a resistor/diode problem in the ignition/hazard system..
Aero 8 GTN #11
