0 members (),
274
101
Topics49,847
Posts837,389
Posts: 222 |
I HATE the gel battery on the S1. Went through 3 in my 3 years of ownership at £140 each time. A conventional battery is a serious improvement on the S2!
Hope your problem gets sorted quickly. Sounds like a starter motor solenoid relay. When my gel batteries died, tyou wouldn't even get the click...
Mr Fezza Talk Morgan Expert
Posts: 2,825 |
Also - could just be the 20 Amp starter fuse. Worth checking it. Usually when my S1 didn't start it was this that had blown.
-------------- Maxxed out!
Posts: 108 Likes: 1
Posts: 108 Likes: 1 |
Hi had the same problem with my mk1 earlier in the year.First check you have the 20amp fuse fitted then try jump leads, if it still clicks you need a new starter motor.I tried all this but the only way it would start was by pushing it. I had a new starter fitted at Millers in High Wycombe and would recommend them highly for there advice a good quick and reasonable priced job. Ring 01494 448158 and talk to Ann
Bill
Posts: 108 Likes: 1
Hi The fuse issue was to upgrade from a 20 amp
Bill
Posts: 534 Likes: 1
Posts: 534 Likes: 1 |
Yes, from a 20amp to a 30amp. Found this out within a week of ownership as the car had blown 3 fuses in that time.
However, when the fuse blew, the starter wasn't even clicking, so I'd doubt that the issue is related to this and sounds more like a starter motor issue or a bad earth as has been suggested beforehand.
Posts: 108 Likes: 1
What I was saying if it starts with jump leads the starter motor is o.k. If it still clicks you need a new starter motor.
Posts: 16 |
Mine started like that (on an S1), I kept blaming the battery, then fuses started blowing. Some say the 15 amp fuse should be 20 amp- but the problem for me that the starter motor was sticking. Ended up fitting a new one and everything else was hunky dorey.
--------- Morgan Aero 8 S5 Porsche Macan S Honda e MV Agusta Turismo KTM 790 Duke
