1 members (Graham, G4FUJ), 387 guests, and 42 robots.
+8Rich 89
Topics49,841
Posts837,324
Christoph
I had a similar issue, could start car without ignition key being turned.
Associated with this were frequent fuse failures.
Auto electrician found too many circuits feeding through Multiple fuses so did a bit of rewiring to a separate Set of upgraded fuses.
Stopped all mystery failures and no longer can start without key.
May pay to see if you have any blown fuses, I could lose one with no issues. Can’t remember which ones they were. Age thing
Nigel
NickCW Offline OP
Originally Posted by Dab of oppo
No immobiliser, Feb. 2013
Thanks, early car then and similar to mine!
Nigel
Can I ask what year your car is, and whether it has the immoboliser? Hoping to find a common link if I can..
Aero 8 GTN #11
My car is April 2020 and yes it does have the immobiliser. Although I have since then immobilised the immobiliser
NickCW Offline OP
Thanks - was yours related to the hazard switch or was it just a live start button?
Aero 8 GTN #11
You have just knocked 8 years of the age of your car Nigel laugh2 . I remember looking at your cars colour when I was ordering mine and wanted to see it but it was rather a long way to go for a look.
Damn those fat fingers and not wearing glasses!
You are so right, should have been 2012!
NickCW Offline OP
Speaking to the factory it sounds like this is a known fault, something to do with a resistor/diode problem in the ignition/hazard system..
Aero 8 GTN #11
