2 members (DJC, Zach),
262
57
Posts837,253
Posts: 198 Likes: 1
Posts: 198 Likes: 1 |
Just had a call with my dealer saying they are having difficulty sourcing s new drivers side electric window motor to replace mine which sounds like it is shredding the cable when going up or down.
Does anyone know what these are from or where I can source one?
Posts: 8,656 Likes: 487
Posts: 8,656 Likes: 487 |
Does anyone know what these are from or where I can source one? It's a pain as it involves a partial strip down, but you should find some numbers & (if lucky) a manufacturers logo on the motor casing that you can then search from
Posts: 378 |
Hi Kevin, I somehow think these were from a Ford Fiesta? Regards T
15 Weissman GT5 11 Aero8 SS 21 Q7 23 RR 24 Def'r 130 1960 XK150 DHC 1970 E-type 2024 Huracan Tech
Posts: 11,520 Likes: 312
Posts: 11,520 Likes: 312 |
I was told it was a BMW motor with the Morgan shaft bound onto it. They had to order it through Morgan and my eyes watered for a bit.
Posts: 2,432 Likes: 66
Posts: 2,432 Likes: 66 |
Kevin. I changed one on my first S1 it was very expensive and I think it had Bmw on it from memory I was new to morgans at the time so I got it from the factory ..If yours is off the car i would try car factors and see if they can match it up.
Em
Posts: 1,767 Likes: 21
Posts: 1,767 Likes: 21 |
I agree, the motor is from a Ford Fiesta MK4. The problem is that the cable at the front of the door is bent through a very tight bend, this means the cable runs on the outer casing and can then fray, causing it to jam. I had my O/S unit replaced a couple of years back and, because of time constraints,I had to buy a complete new set up from the factory - ouch!! Sadly, they won't sell just the cable.....  If you are lucky, you can just replace the simple Bowden cable (but it has an odd 'hockey stick' / 'L' shape end to it) and the length is critical. James
Aero8 , Series 1 - Boston Green RR Evoque P300E Autobiography Smart Brabus Convertible Monkey Z125
Just to put things in some context though I recently had to change the complete mechenism on our cheap tin top, 280 quid plus fitting.......Ouch.
Posts: 2,431 Likes: 17
Posts: 2,431 Likes: 17 |
I think it's Fiesta too. Somewhere on this forum there is a list of S1 parts and their origin.
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 2,049 Likes: 12
Sir S1'a'lot Talk Morgan Expert
Posts: 2,049 Likes: 12 |
It’s a “sticky”.
Top Of the page
2002 Aero 8 S1 2023 Plus 4 (woman’s)
Posts: 198 Likes: 1
Thanks as usual for all the info guys. The dealer took a photo of the offending article but apparently they cannot find it at all online. I'm assuming they have checked the factory route and as is becoming quite common it is no longer available but I will double check.
I'll also let them know it is probably ford fiesta mk4 as mine definitely doesn't have any bmw markings I was told as that was my first thought.
