8 members (Grumpy2, gaston, Image, Alan Patterson, RichardV6, Bunny, Montegue, Hamwich), 298 guests, and 50 robots.
John V6 74
+8Rich 68
DaveW 67
9,203 Registered Users
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Morgan 3 Wheeler song
by Dutch - 21/07/25 12:31 AM
by Oskar - 20/07/25 04:13 PM
Goggle eyed
by Roady - 19/07/25 06:16 PM
Topics48,340
Posts812,969
Members9,203
PPP356
#658033 23/08/20 08:53 PM
I am aware of several 3.7L Roadsters suffering terminal engine damage during enthusiastic track day driving as a result of oil starvation. Apparently on long track corners or a quick left to right or visa versa the sump oil gets forced up one side of the sump housing and leaves the strainer mid-air. The result of which you can guess.
Has anyone had a sump modified ( baffled ) or gated thus reducing the oil slop and mitigating the starvation, if so who carried out the work.
As you may guess I am one such owner who enjoys one or two-track days each year (COVID allowing) and has now purchased a set of wheels shod with soft compound rubber thus potentially bring the disaster closer.
When i last spoke to the factory about this there solution was 'just stick an extra liter of oil in the engine'. not sure I am happy with this as I am told this act can cause hydraulicing and subsequent damage of a different kind.
Any advice/experiance welcome.
I think this is probably directed at Simon (SIFAB) because if I need a modified sump he is probably my man.
Yes, try Simon. Cain at Wolf performance also does them.
1969 4/4
1995 plus 8
2002 Aero S1
2013 M3W
2014 Plus 8
Hello dear Paul,
facing the same concerns i went for an ACCUSUMP additional oil feed system... works fine! :-)
drive 2015 Roadster 3.7
I’ve been asked a couple of times about this
I’ve got a dummy engine lined up to prototype on, just need some time ....
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
HI Simon.
I think quite alot of 3.7l owners would be interested in this. When do you think you can develop a solution.
Id be happy to run my car over so you have something to work on if that helps.
